Robin Hood DVD Fail
kirkdickinson
Robin Hood DVD Fail
Post by kirkdickinson »
I have tried several times to process the newest Robin Hood DVD.
It fails every time after about 2 minutes into the actual attempted burn.
I get this message "Fatal error occurred, program will now exit". and when I click ok MakeMKV closes.
I end up with one file named title_t00.mkv which is 0KB.
The last line in the working log before the lock up says:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTBLE ERROR' occurred while reading '/VIDEO_TS/VTS_24_1.VOB' at offset '13062144'
That exact same error occurs six times before the lock.
I have examined the surface of the disk and it appears pristine.
Re: Robin Hood DVD Fail
Uncorrected errors are parts of the disk that your drive cannot read; cleaning it usually helps, but it is possible damaged.
This should not cause the system to crash, though; Windows should simply report the error.
kirkdickinson
OK, plot thickens. I went back to RedBox and rented a different DVD before returning the one I had. I took it home to my MacBook Pro. IT DOES THE EXACT SAME THING. I have the same error messages and the program closes after clearing the error. Exactly the same as on the PC.
There has to be a structure on this DVD that MakeMKV is having problems with. I have had corrupt discs before where only parts get copied or the disk won't copy, this is not acting the same way.
Robin Hood has been on my RedBox wish list for a while and just this week came to the box. Both of these disks look brand new. No smudges, scratches or pits. Many RedBox rentals look pretty rough.
Is there a way to submit a log of this?
kirkdickinson
Here is the debug log.
Debug log started at Thu Feb 28 02:29:53 2019 , written by MakeMKV v1.14.2 darwin(x64-release)
001005:0000 MakeMKV v1.14.2 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/kirkdickinson/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL MATSHITA DVD-R UJ-8A8 HB14d" opened in OS access mode.
DEBUG: Code 2365587456 at (/YVlr[>h*N'AVA5k:29394620
DEBUG: Code 0 at ?V0Q|8za{I@EyeN"g:121261819
DEBUG: Code 0 at ?V0Q|8za{I@EyeN"g:29393815
Title skip vts=24 pgcn=1 hash=B06B18ECA23F4A61
003028:0000 Title #1/0/6 was added (2 cell(s), 0:02:26)
003028:0000 Title #3 was added (1 cell(s), 0:04:37)
003028:0000 Title #9 was added (7 cell(s), 1:04:21)
003028:0000 Title #10 was added (1 cell(s), 0:06:37)
003028:0000 Title #11 was added (1 cell(s), 0:21:42)
003028:0000 Title #12 was added (1 cell(s), 0:06:23)
003028:0000 Title #13 was added (1 cell(s), 0:08:34)
003028:0000 Title #14 was added (1 cell(s), 0:09:49)
003028:0000 Title #15 was added (1 cell(s), 0:05:21)
003028:0000 Title #16 was added (1 cell(s), 0:05:55)
003028:0000 Title #17 was added (6 cell(s), 0:08:24)
003025:0000 Title #18 has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #19 has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #21 was added (1 cell(s), 0:02:13)
003025:0000 Title #22 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #23 has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #34 has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #35 has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #36 has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #37 has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #46 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #47 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #48 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #49 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #52 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #53 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #54 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #55 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 335544580 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=20 pgcn=1 hash=7D2D709E6504CB98
DEBUG: Code 352322052 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=2 hash=7C1762508F4B5E5F
DEBUG: Code 352322308 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=3 hash=EE57C099A45EB88C
DEBUG: Code 352322564 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=4 hash=E99EDCBD84FEE30E
DEBUG: Code 352322820 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=5 hash=5F6229E482398173
DEBUG: Code 352323076 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=6 hash=CD898E9948ED3149
DEBUG: Code 352323332 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=7 hash=449017588D3ADBFD
DEBUG: Code 352323588 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=8 hash=FC78F55C74432EDA
DEBUG: Code 352323844 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=9 hash=2BC3725803CD03EF
DEBUG: Code 352324100 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=10 hash=73E4EB6A7486C9A2
DEBUG: Code 352324356 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=11 hash=094B1F84A3427A9D
DEBUG: Code 352324612 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=12 hash=22F595A4A7C95E0B
DEBUG: Code 352324868 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=13 hash=C1B4D874D91E0D47
DEBUG: Code 352325124 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=14 hash=A0641AE8903C5716
DEBUG: Code 352325380 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=15 hash=79A0050464D2F60E
DEBUG: Code 352325636 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=16 hash=D9E1794D44D4C323
DEBUG: Code 352325892 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=17 hash=5D780A42DE684A1F
DEBUG: Code 352326148 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=18 hash=D65E95B19A623B77
DEBUG: Code 352326404 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=19 hash=200E3F4A3244BC27
DEBUG: Code 352326660 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=20 hash=A8D97ECBAC4AB2C9
DEBUG: Code 352326916 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=21 hash=CEA60720C6FE9760
DEBUG: Code 352327172 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=22 hash=29458568353140C5
DEBUG: Code 352327428 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=23 hash=FCA4BB0B2702BD0E
DEBUG: Code 352327684 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=24 hash=89B5A1C6FDE1D317
DEBUG: Code 352327940 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=25 hash=20870E1AEB2CB31F
DEBUG: Code 352328196 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=26 hash=76D0BA482ECCD45D
DEBUG: Code 352328452 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=27 hash=CF6179FDB2C38002
DEBUG: Code 352328708 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=28 hash=A3D5024E0DD4AE59
DEBUG: Code 352328964 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=29 hash=479FB2C46E9FE8CF
DEBUG: Code 352329220 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=30 hash=9AD825F9322AA248
DEBUG: Code 352329476 at EnT#jQ5phhj{*{Ay:213133526
Title skip vts=21 pgcn=31 hash=914D295C96150659
003025:0000 Title #57/31 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=1 pgcn=1 hash=CAA215E5CD79D137
001003:0020 DEBUG: Code 100860416 at I_'Qak}mzNCqE;GI:121269317
001003:0020 DEBUG: Code 100860416 at Y&wUp`xLsO7H2BN6:121262417
003028:0000 Title #59 was added (20 cell(s), 1:58:21)
001003:0020 DEBUG: Code 10551303 at EnT#jQ5phhj{*{Ay:213142496
001003:0020 DEBUG: Code 0 at EnT#jQ5phhj{*{Ay:121274998
001003:0020 DEBUG: Code 0 at a*kJ^xCf~iS<O</zpa:29394229
003035:0000 CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
003037:0000 Cells 1-1 were removed from title start
003038:0000 Cells 19-19 were removed from title end
003028:0000 Title #60 was added (17 cell(s), 1:55:52)
003019:0000 Cells 2-4 were skipped due to cell commands (structure protection?)
003028:0000 Title #61 was added (19 cell(s), 1:56:16)
003028:0000 Title #62 was added (19 cell(s), 1:53:57)
003028:0000 Title #63 was added (17 cell(s), 1:55:52)
003028:0000 Title #64 was added (17 cell(s), 1:55:52)
003028:0000 Title #65 was added (19 cell(s), 1:54:20)
003028:0000 Title #66 was added (19 cell(s), 1:54:19)
003028:0000 Title #67 was added (20 cell(s), 1:58:21)
003028:0000 Title #68 was added (17 cell(s), 1:55:52)
003028:0000 Title #69 was added (20 cell(s), 1:58:21)
003028:0000 Title #70 was added (17 cell(s), 1:55:52)
003028:0000 Title #71 was added (20 cell(s), 1:58:21)
DEBUG: Code 369099271 at EnT#jQ5phhj{*{Ay:121266189
Title skip vts=22 pgcn=2 hash=09E76A6A483862AA
003027:0000 Title 1 in VTS 23 is equal to title 1 and was skipped
003027:0000 Title 1 in VTS 22 is equal to title 1 and was skipped
001003:0020 DEBUG: Code 0 at 6=ZWq^;#knU?K("VtgD:213132652
vobs=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
vobs=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
vobs=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
vobs=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
vobs=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
vobs=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
vobs=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
vobs=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
vobs=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
005014:0000 Saving 18 titles into directory /Volumes/5TB-Drive/Video Unprocessed/_ROBIN_HOOD_7487
005001:0308 File /Volumes/5TB-Drive/Video Unprocessed/_ROBIN_HOOD_7487/title_t00.mkv already exist. Do you want to overwrite it?
001003:0020 DEBUG: Code 0 at W2~>j2;_}k}XQ<zZe:121262026
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 1650688, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 2416640, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 3182592, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 3948544, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 4714496, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 5480448, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 6246400, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 7012352, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 7778304, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 8544256, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 9310208, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 10076160, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 10842112, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 11608064, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_24_1.VOB' is corrupt or invalid at offset 12374016, attempting to work around
001003:0020 DEBUG: Code 1073741829 at Y&wUp`xLsO7H2BN6:121262417
001003:0020 DEBUG: Code 100927744 at I_'Qak}mzNCqE;GI:121269317
001003:0020 DEBUG: Code 100927744 at Y&wUp`xLsO7H2BN6:121262417
002003:0000 Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/VIDEO_TS/VTS_24_1.VOB' at offset '13062144'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '13062144'
DEBUG: Code 1073741829 at oR=Y1>iTZ?NprdY6aW:121263015
001003:0020 DEBUG: Code 1073741829 at oR=Y1>iTZ?NprdY6aW:29395080
DEBUG: Code 100927744 at oR=Y1>iTZ?NprdY6aW:121263015
001003:0020 DEBUG: Code 100927744 at oR=Y1>iTZ?NprdY6aW:29395080
001003:0020 DEBUG: Code 0 at )o^[7#n9G2L$z#ybU`mC:29395011
001003:0020 DEBUG: Code 0 at 6=ZWq^;#knU?K("VtgD:213129915
001003:0020 DEBUG: Code 0 at )o^[7#n9G2L$z#ybU`mC:29394459
001003:0020 DEBUG: Code 6378 at )o^[7#n9G2L$z#ybU`mC:29393286
001003:0020 DEBUG: Code 0 at "O@}W`.ZWi2muU=C9/=\I:213136608
001003:0020 DEBUG: Code 0 at 66AO3<:sL"B-bW4-D/]#:29394022
001003:0020 DEBUG: Code 0 at 66AO3<:sL"B-bW4-D/]#:29398507
001003:0020 DEBUG: Code 0 at "O@}W`.ZWi2muU=C9/=\I:213136332
001003:0020 DEBUG: Code 0 at "O@}W`.ZWi2muU=C9/=\I:213136240
001003:0020 DEBUG: Code 0 at tpO\,-@n(vKyxlvT*uk:121263038
001003:0020 DEBUG: Code 0 at tpO\,-@n(vKyxlvT*uk:121264441
001003:0020 DEBUG: Code 0 at tpO\,-@n(vKyxlvT*uk:29395747
001003:0020 DEBUG: Code 0 at tpO\,-@n(vKyxlvT*uk:121266189
001003:0020 DEBUG: Code 0 at \8{QS"5#OFT<aB#[:213130743
001003:0020 DEBUG: Code 0 at \8{QS"5#OFT<aB#[:121262141
001003:0020 DEBUG: Code 0 at tpO\,-@n(vKyxlvT*uk:121264740
Follow the procedure in the FAQ link in my signature and "box up" the requested files (including this log) and email it to support@makemkv.com so that Mike can look at it. If there is any system log information about it, that probably would be helpful (assuming the MakeMKV actually crashed).
Email is the fastest way to get the author's attention.
kirkdickinson
Thanks, I sent that info in. :)
kirkdickinson
Typically, will I hear back with my report, or does it just help to make the program work better?
If Mike needs more information, you'll get an email explaining what he needs. How soon you'll get that depends on what he's working on at the moment.
I'd give it a week.
kirkdickinson
OK, thanks.
ProfTheory
Post by ProfTheory »
I copied a title with 16 chapters and 4.8 GB. Disk is from Redbox.
nateliv
Post by nateliv »
I live in Nottingham. Anything associated with Robin Hood is pants
