Robin Hood (2018) playlist obfuscation
Re: Robin Hood (2018) playlist obfuscation
I doubt the MTL settings match across users. Default is 120 seconds; I have mine set at 30, and I've seen people encourage larger settings as a way to fight obfuscation (reduce the number of titles to look through).
The important thing is the :Source file name:" shown in the info window.
morikaweb
Post by morikaweb »
I am also having an issue finding the correct Playlist on a Canadian Steel book edition from Best Buy. I cannot find any of the listed source files, and all my segment maps start with 513. Are there any other Canadians with the correct playlist?
RxGator
Post by RxGator »
Vanorie wrote: Tue Feb 19, 2019 11:34 am I did not have the above file. This is the one that worked for me.
Title information
Source file name: 00855.mpls
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Segment map: 502,512,501,506,514,515,505,510,504,511,508,503,513,509,507
File name: Robin Hood_t299.mkv
How in the world were you able to figure out that this is the correct playlist with over 100 to choose from? I trust you but tell me you had a slick method of testing besides going through each one, right?
Steveredrum
Post by Steveredrum »
Yes Retail (U.S.A) - Red Box - Netflix - Amazon - Retail (U.K) which seem to be the most Used MPLS type not just this one worked for me to stop confusion
thedigitalhobo
Post by thedigitalhobo »
RxGator wrote: Tue Feb 26, 2019 5:13 am
Title information
Duration: 1:56:08
Chapters count: 16
Segment count: 15
https://www.makemkv.com/forum/viewtopic.php?f=6&t=16251
The_Dee_Offish
Post by The_Dee_Offish »
I have a Canadian pressing of the disc, and the correct playlist for this one turns out to be:
Source file name: 00289.mpls
Segment map: 513,505,509,515,512,514,508,510,507,501,506,503,504,511,502
File name: Robin Hood_t115.mkv
Sush1988
Post by Sush1988 »
I have read on John Wick playlist question forum that the playlist that comes with FPL_Mainfeature should be the right playlist.
When I opened RobinHood Redbox Version I got both playlists FPL_Mainfeature(00470.mpls) and also the confirmed one 00855.mpls also
Which way should I go Guys ?
