MakeMKV 1.14 problem
MakeMKV 1.14 failed to convert two disks that I did convert by reverting to version 1.12.0. The drive hangs up trying to read over and over. Log is attached. Mac OS 12.6
- MakeMKV_log.txt
- (28.48 KiB) Downloaded 882 times
Re: MakeMKV 1.14 problem
Send an email to support@makemkv.com with a link tot his topic, to make sure Mike sees it sooner.
- Contact:
Appears to be a bug in 1.14.0 . Please send testdump per instructions at http://www.makemkv.com/onlinehelp/testdump.html , this would help a lot. Thanks!
- Contact:
Fixed in 1.14.1
I have an internal dvd drive in my mac and was borrowing an external blu-ray player from my brother. I experienced the slow (lots of reads) problem using the blu-ray drive on some discs with 1.14.0 but 1.14.1 fixed that problem. I gave the blu-ray drive back and was trying to use 1.14.1 with my internal dvd drive. Makemkv sees the disc and content fine, but when i hit the makemkv button after a tiny bit of activity makemkv just kinda sits there doing nothing. It isn't constantly spinning up the drive, like 1.14.0 did with blu-rays. It appears to be doing nothing. No drive sound. I waited over 9 minutes, nothing. I tried 1.14.1 with two discs that I've done before with makemkv, same results. Installed 1.14.0 again, tried same discs, same nothing. I installed 1.12.3, boom, instant file creation with 1.12.3.
I installed 1.14.1 again, using the same disc as used in 1.12.3 above, it is paused at output size of 7.6k after 7 minutes of time.
1.14.1 seems to work with some dvds for me, but i have identified 2 dvd so far, with little testing, that 1.14.1 just doesn't seem to act on.
Any questions just ask.
Thanks,
Greg
Thanks,
Greg
Running into the same issue with some disks in 1.14.1 and 1.14.2 in Ubuntu, but a quick search came up with this thread
