MakeMKV v1.14.2 win(x64-release) started
Using LibreDrive mode (v04 id=6F4CB5E20C3C)
Saved AACS dump file as C:\Users\longmire/.MakeMKV/MKB20_v66_Bohemian_Rhapsody_0F5C.tgz
So, am I supposed to send the .tgz file to you or do I just have to wait until the next round of hashkeys.txt comes out? I did download Hashkeys.txt today 2-12-2019.
Cannot open Bohemian Rhapsody UHD
Re: Cannot open Bohemian Rhapsody UHD
Yes, dump should be sent to svq@makemkv.com .
BTW it is no longer necessary to manually download the key file. I has been automatic for a few MakeMKV versions now (as long as 'Allow contacting web server...' is checked in General prefs tab),
bmillham
I just got home from work with my new copy of BR UHD, and it opened and is ripping fine. That was a quick update
stuckinkodiagain
Does not rip for me tonight using the latest version of MakeMKV (1.14.2) and connected to the internet. My copy was purchased from Amazon; where was yours?bmillham wrote: Wed Feb 13, 2019 4:03 am I just got home from work with my new copy of BR UHD, and it opened and is ripping fine. That was a quick update![]()
Regardless, dump file has been submitted to svq@makemkv.com. Thanks to the developers, as always!
bmillham
Mine was purchased at Walmart.stuckinkodiagain wrote: Wed Feb 13, 2019 4:49 amDoes not rip for me tonight using the latest version of MakeMKV (1.14.2) and connected to the internet. My copy was purchased from Amazon; where was yours?bmillham wrote: Wed Feb 13, 2019 4:03 am I just got home from work with my new copy of BR UHD, and it opened and is ripping fine. That was a quick update![]()
bobtimms
Can't open my copy purchased from VUDU which is supplied by Walmart. Using MakeMKV v1.14.2 .
Dump file has been submitted to svq@makemkv.com.
Blauman
Ripping mine as I type this. Disc purchased from Best Buy on Tuesday.
slongmire
Purchased via Amazon - Ripped successfully this evening - Watching it now on my LG OLED - THANKS for rapid key replacement!
averageschmoe
I also can not open Bohemian Rhaspody. I'm using a registered version of MakeMKV on Ubuntu and everything is up-to-date and MakeMKV is allowed to contact the server, I even manually downloaded the keys-hashed.txt file when nothing else worked and still am unsuccessful. When I open the txt file I don't see an entry for the movie. Any suggestions?
jayper
Worked for me this morning. Worth giving it another shot now.
Thanks so much!
Thanks so much!
bobtimms
Mine worked today too. Thanks Mike
mfraz74
Received Bohemian Rhapsody UHD as a promo from Sony - it has "For promotional use only not for resale" and MakeMKV won't open it.
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Saved AACS dump file as /home/mfraser/.MakeMKV/MKB20_v66_Bohemian_Rhapsody_7FB7.tgz
st4evr
Did you submit the dump file as it has been discussed and advised many times over?mfraz74 wrote: Tue Nov 12, 2019 10:28 pm Received Bohemian Rhapsody UHD as a promo from Sony - it has "For promotional use only not for resale" and MakeMKV won't open it.
https://www.makemkv.com/forum/search.ph ... +this+disc
Including in the posts above of this very thread.
mfraz74
Yes, I did and the following day the disc could be read without issues.st4evr wrote: Tue Nov 12, 2019 11:36 pmDid you submit the dump file as it has been discussed and advised many times over?mfraz74 wrote: Tue Nov 12, 2019 10:28 pm Received Bohemian Rhapsody UHD as a promo from Sony - it has "For promotional use only not for resale" and MakeMKV won't open it.
