Robin Hood (2018) playlist obfuscation
taseldor
#1 Post by taseldor » Thu Feb 14, 2019 11:46 am
Anyone have any idea which one is the right one? Thank you!
Steveredrum
Re: Robin Hood (2018) playlist obfuscation
#2 Post by Steveredrum » Sat Feb 16, 2019 11:03 am
Yes the the correct PLAYLIST please no sign of it anywhere else on the net
Found And Tested For Retail (U.S.A) its - [00610.MPLS]
hvnphoto
#3 Post by hvnphoto » Sun Feb 17, 2019 3:48 pm
US Retail
Title information
Source file name: 00610.mpls
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Segment map: 512,503,511,505,508,515,509,514,507,510,513,502,506,501,504
File name: Robin Hood_t105.mkv
taseldor
#4 Post by taseldor » Mon Feb 18, 2019 11:49 am
Steveredrum wrote: Sat Feb 16, 2019 11:03 amFound And Tested For Retail (U.S.A) its - [00610.MPLS]
Thank you!
book1
#5 Post by book1 » Tue Feb 19, 2019 7:07 am
Any other avenues tested?
Vanorie
#6 Post by Vanorie » Tue Feb 19, 2019 11:34 am
I did not have the above file. This is the one that worked for me.
Title information
Source file name: 00855.mpls
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Segment map: 502,512,501,506,514,515,505,510,504,511,508,503,513,509,507
File name: Robin Hood_t299.mkv
WAYFLIX
#7 Post by WAYFLIX » Tue Feb 19, 2019 2:42 pm
Vanorie wrote: Tue Feb 19, 2019 11:34 am I did not have the above file. This is the one that worked for me.
Title information
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Is that Redbox??
killakel77
#8 Post by killakel77 » Tue Feb 19, 2019 3:15 pm
WAYFLIX wrote: Tue Feb 19, 2019 2:42 pm
Title information
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Is that Redbox??
This is the correct mpls for Redbox version. I did a side by side comparison to confirm.
WAYFLIX
#9 Post by WAYFLIX » Tue Feb 19, 2019 3:55 pm
killakel77 wrote: Tue Feb 19, 2019 3:15 pm
Title information
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Is that Redbox??
dp5081
#10 Post by dp5081 » Tue Feb 19, 2019 4:38 pm
i found that the file name comes up as Robin Hood_t309.mkv. it has the same Segment Map as what is posted with the 299.mkv
MSDowney
#11 Post by MSDowney » Wed Feb 20, 2019 6:35 pm
Thank you guys. I just got on here looking for this.
DBond
#12 Post by DBond » Thu Feb 21, 2019 2:22 am
Does anybody know the playlist for the Canadian version? My segment maps all start with 513.
MAJWoody
#13 Post by MAJWoody » Thu Feb 21, 2019 11:06 pm
Weird, I get the same segment map:
But the file name I get is t297.mkv
Anyone know what this is all about?
#14 Post by Woodstock » Fri Feb 22, 2019 1:47 am
Title numbering is done for titles that are at least as long as your minimum title length (MTL). Someone with 1800 seconds set for MTL will have a different numbering than someone with MTL 1 second, or even the default 120.
The important thing to look at is the "Source file name", which you will see in the Info window when you highlight a title.
MAJWoody
#15 Post by MAJWoody » Fri Feb 22, 2019 4:07 am
Gotcha... thanks Woodstock.... so, I am assuming that most here in the forum have their MTL set to the same number. Is this true and if so, what is the number?
Thanks in advance-
MAJWoody
