Epedemic
Post by Epedemic »
PSUHammer wrote:
Sun Feb 17, 2019 6:53 pm
Tried this with Last Jedi UHD.
Don't waste your time with TLJ or other Disney releases. They have a "fake" DV track that is just there so they can claim their discs have DV and trigger TV's to show DV. The track on TLJ is just 76MB, whereas all other discs have DV tracks between 2 and 10GB
Mouth_of_Sauron
Post by Mouth_of_Sauron »
Like others, I'm hoping that in the future we might be able to get DV in MKVs.
For this reason I'd like to be able to demux the DV MP4s in the future, but when I try tsMuxer doesn't recognise the DV stream so only demuxes the base video and audio. How can I demux a DV MP4 back out into the 3 individual files (Base HEVC, DV HECV, and AC3) ready to be muxed into a different container?
EDIT: Edited for clarity and typos.
Last edited by Mouth_of_Sauron on Tue Feb 19, 2019 2:21 am, edited 1 time in total.
Grencola
Post by Grencola »
Hey so after messing around with tsmuxer and powershell scripts etc, I realized there's a way simpler way using eac3to and cmd prompt lol :) so I took the time to make a quick little program using winrar sfx. It's a fully automated one click method to make a dv mp4. I made one for both m2ts and mkv. I haven't tried playing mkv on the tv yet but the output mp4 seems identical so it's worth testing it out. and no, it's not malware (you can literally just open it with winrar instead if you want) :P
you can point it right at a full uhd bd folder (\bdmv\streams\) if you want, as I have it set to find the largest m2ts and use that. but putting your desired m2ts / mkv file into it's own folder is probably best.
let me know what you think, and what I should add/change :)
cheers!
m2ts to mp4: https://bit.ly/2TX4yYW
mkv to mp4: https://bit.ly/2EhJwi3
PSUHammer
Post by PSUHammer »
Mouth_of_Sauron wrote:
Mon Feb 18, 2019 7:55 pm
I don't have The Last Jedi because it sucked! Might be worth grabbing it though if it's a good one to test with. Thanks
Yeah, it sucked. But I know it is supposedly a good test according to some sites.
This site says it is legit 4k filmed and mastered? https://4kmedia.org/real-or-fake-4k/5/
Grencola
Post by Grencola »
Tried this with Last Jedi UHD. Tsmuxer was unable to parse the playlist (800) but I was able to find the stream file (MT2S) and demux them. I have the base file, an enhanced file and the AC3 audio file. I used the following command:
"mp4muxer.exe --dv-profile 7 -i dv.base.hevc -i dv.enhancement.hevc -i dv.audio.ac3 --media-lang eng -o DolbyVision.mp4"
The output creates the mp4 container successfully. I am using a Plex media server with a Windows 10 machine as the server. I am watching on a TCL R617 65" set via the Roku Plex app. The movie plays fine but is recogized as an HDR10 format, not Dolby Vision.
Anyone else have any luck? Could it just be this set or Plex?
try plugging a usb hdd (exfat) into your tv and see if it triggers dolby vision. if so then it's the plex app, if not then your tv can't decode dv-profile 7 (dual layer) and dv won't be possible without a uhd-bd player.
PSUHammer
Post by PSUHammer »
I made a second attempt at getting this to work. This time, I used Black Panther UHD disk. I was able to demux the files successfully and run the same command as above. It created the mp4 successfully but Plex and/or the TCL r617 TV only recognizes the file as regular HDR10 content.
I am throwing up my hands for now.
Mouth_of_Sauron
PSUHammer wrote:
Tue Feb 19, 2019 4:11 am
You're using Plex on the Roku connected to TV via HDMI correct?
Can you put the MP4 on a USB HDD or flash drive and plug it into the TV directly? Does the TCL have a Plex app you could try with to rule out an issue with the Roku?
Using the described method is working for me, but I use Emby directly on my LG C8 TV (Emby is a media server like Plex).
Does the TCL have a dynamic tone mapping function? I've been doing some eyeball comparisons and I'm not convinced that DV looks noticeably better than regular HDR10 with LG Dynamic Tone Mapping. Admittedly comparisons are very difficult without identical TVs side by side (which I don't have). If your TV has a similar function then you may find you're not missing much if you can't get DV to work.
Last edited by Mouth_of_Sauron on Tue Feb 19, 2019 7:04 am, edited 1 time in total.
Mouth_of_Sauron
powdeau wrote:
Mon Feb 18, 2019 6:12 pm
I accidentally put two different tracks from two different movies in makemkv and when I played the file in DV, I could see the second layer in the background with different picture. So I believe we get the metadata.
I just did this on purpose to see what would happen. I couldn't see a whole different picture in the background, but the colours of the main movie were all over the place so it is definitely doing something.
rezneck
Post by rezneck »
Hi, did anyone manage Saving Private Ryan ? I keep getting an error on tsmuxer, here is my log:
Error : Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: E:\BDMV\STREAM\00005.m2ts
Error code : -2
Log : Network Optix tsMuxeR.  Version 2.6.12. www.networkoptix.com
HEVC muxing fps is not set. Get fps from stream. Value: 23.976
Decoding AC3 stream (track 3): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 5.1
Decoding AC3 stream (track 4): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 5.1
B-pyramid level 2 detected. Shift DTS to 3 frames
Decoding PGS stream (track 5):  Resolution: 1920:1080  Frame rate: 23.976
I managed despicable me 2 and star wars, it was a bit of a pain to find the correct tracks for despicable me 2 but using BDinfo I got it properly.
For SPR the whole movie is on a single m2ts (00005.m2ts) and there is a playlist that only have this m2ts (00800.mpls) but tsmuxer crashes regardless if I use m2ts directly or the mpls.
Grencola
Post by Grencola »
rezneck wrote:
Tue Feb 19, 2019 2:14 pm
Error code : -2
demux each track individually. tsmuxer is finicky. eac3to is way easier. put it in your m2ts folder and in cmd prompt just type:
eac3to.exe 00005.m2ts 1: baselayer.hevc 2: dvlayer.hevc 3: audio.ac3 -core -640
it will convert the audio and everything all for you. then just use mp4muxer without those output files.
alternatively you can use the program I made a few comments above and it should work flawlessly with just a single click :)
rezneck
Post by rezneck »
Thanks, I got it working with your program, one note, when it is done, it will delete all files in the folder where is your program, I placed the program in the BDMV folder directly so it wiped all my files ! (except the mp4 output ofc)
Mouth_of_Sauron
Grencola wrote:
Tue Feb 19, 2019 5:28 pm
What do you mean it will convert the audio?
What is the appropriate command to run this demux with it just pulling out the AC3 core from the TrueHD with no conversion or re-encoding?
Won't the above command extract the core (which is usually 448 Kbps) and re-encode it into 640Kbps? Wouldn't it be better to just pull out the original 448Kbps core untouched?
Grencola
Post by Grencola »
Tue Feb 19, 2019 8:05 pm
What is the appropriate command to run this demux with it just pulling out the AC3 cored from the TrueHD with no conversion or re-encoding?
fyi if you type eac3to.exe file_name.m2ts it will list all the tracks. hd-audio is always track 3 if there's dv, otherwise it's track 2..
you would just type:
eac3to.exe 00005.m2ts 1: base.hevc 2: dv.hevc 3: audio.ac3 -core
-core extracts the core audio, yes.. but naming it a .ac3 file means it will convert say the dts core to ac3. if you want the core dts track you need to name it *.dts but mp4 wants ac3 so just name it audio.ac3 and you're good. truehd has an ac3 core already so no converting there. and -640 takes the high bitrate and makes it 640kbps instead of the default 448kbps, so slightly better sound as ac3 maxes out at 640 so may as well get the most you can out of the hd-audio. eac3 can go to 1536kbps but you need XMedia Recode for that.
Mouth_of_Sauron
Grencola wrote:
Tue Feb 19, 2019 8:16 pm
Thanks, the -640 switch makes sense when converting a DTS core to highest quality AC3.
One thing I'm still not clear on though. What's the point of re-encoding an 448kbps AC3 core to 640kbps? You can't add quality by upsampling. If anything wouldn't the process of decoding and re-encoding degrade the quality? Wouldn't you end up with an AC3 track with a higher bitrate, but potentially worse sound than the original lower bitrate core?
Maybe I'm missing something? Am I correct that "... 3: audio.ac3 - core" literally just pulls the core AC3 untouched (i.e. it doesn't decode the original 448kbps and then re-encode back to 448kbps)? Does that make sense?
I've also had a play with XMedia Recode to convert the TrueHD 7.1 to EAC3 5.1, but I'm not sure I like that solution as (unless I'm doing it wrong) you have to completely remove the two back channels rather than fold them into the 5.1 track. Surely this will result in an EAC3 track with better quality sound than the AC3 core, but it will have an inaccurate 5.1 mix.
Thanks again
cyperous
Post by cyperous »
Jhoopes517 wrote:
Wed Feb 13, 2019 12:27 am
Grencola wrote:
Tue Feb 12, 2019 8:47 pm
Shasarak wrote:
Tue Feb 12, 2019 3:40 pm
People recommending the Sony X700 as a Dolby Vision media player should be a little careful.
It does correctly play back dual-layer DV if it is muxed into MP4 format, as described in this thread (meaning no HD audio). However, it doesn't play back dual-layer DV in M2TS format.
If you try and play a file like that via DLNA, it plays as HDR10. If you copy the file onto an external drive and connect directly via USB, then you'll get Dolby Vision output, but it still isn't actually reading the DV metadata from the file - instead it is simply reading the HDR10 stream and then converting that to DV on the fly.
The results still look quite good doing that (and if the M2TS file is only HDR10 in the first place then it will convert it to DV, and that can look very good); but it's not the same as actually using the dual-layer DV information in the file.
so forget mp4 for a second and just talk m2ts.
Even when both the player and the tv are showing dolby vision, it's still faking it? because that's what happens I play both a uhd disc and an m2ts from usb hdd. there's no difference I can find in any setting or menu or info display that is different between disc and m2ts usb. how is one to tell? I can see it being fake over dlna though, where only one of the two devices is showing dolby vision - as I said it seemed iffy, but I honestly can't see the dif with disc vs usb...
From that screenshot you posted a couple days back with playback of the .m2ts over USB it only shows the DoVi coming from the TV. It doesn't show it is getting DoVi from the x700. Can you please double check? Every .m2ts I tried (I tried a couple for sure!) only showed hdr10 from the .m2ts on the x700, but DoVi on the TV cause it was being converted as described by @shasarak
That may have been true of older firmware of the X700 however I just tried playing a direct HDR10 presentation file on the X700 and both my TV and the X700 reported HDR10. However if I take the same file with the DV layer I get the TV and the X700 to report dolby vision. I can't recall what firmware I'm running but I'm convinced that it's working.
