Fatal Error Hashed Keys COCO UHD
cv15xbmc
#1 Post by cv15xbmc » Sat Feb 09, 2019 3:50 am
So I've been using a LG BH16NS55 version 1.02 with Make MKV 1.14.2.
So far I've managed to rip all UHD's relatively easy without troubles.
Mamma Mia kept on stopping 3/4 of the way through and said "Fatal Error" and then said something about hashed keys, but eventually it worked because I just kept trying it again and again.
COCO however, I've tried about 5 times already and it keeps failing sometimes 1/4 way through sometimes half or 3/4 of the way through and comes up with the same error. Any idea on why this might be?
There are two other discs I've had so far that couldn't even open; Fury and X-Men First Class, of which I sent the dumps through to Make Mkv.
Also, some UHD discs come up with 2 or 3 files that are movie size. They didn't use to do that, but they seem to be still ripping fine. It's just weird that several movie files show up.
st4evr
Re: Fatal Error Hashed Keys COCO UHD
#2 Post by st4evr » Sat Feb 09, 2019 5:10 am
There is a post literally a couple of post down from yours which may help:
viewtopic.php?f=12&t=18888
Try that first. Forum search function works/helps against specific errors to see if they have already been reported/discussed as well.
Regarding Fury read this:
viewtopic.php?f=12&t=17489&hilit=Aacs+2.1
Sending the dump to Mike for that disc will not result in support at this time.
For X-men if it’s the Volume key Unknown error then yes, wait for Mike to add it since you already submitted the dump.
cv15xbmc
#3 Post by cv15xbmc » Sat Feb 09, 2019 1:31 pm
Yea lol I posted this and then saw the topic.
I tried that method for coco and it still didn’t work.
Thanks for your help.
cv15xbmc
#4 Post by cv15xbmc » Thu Feb 14, 2019 7:30 am
I don’t know if this helps, but it just occurred to me I did what that post suggested and I completely a BMV back up instead of just owning the disc and choosing a file.
It extracted fine, but when I opened the BMV file of my HD to turn into a mkv it just kept on stopping a certain way through and said error.
So im not sure if the actual file is stuffed now?
corzamoon
#5 Post by corzamoon » Sat Feb 16, 2019 8:25 am
Aussie X-Men First Class is also giving me the can't be decrypted message. This is also the 2nd disc to be replaced.
cv15xbmc
#6 Post by cv15xbmc » Sat Feb 16, 2019 10:25 am
Apparently it will be fixed in the next hashed keys update.
corzamoon
#7 Post by corzamoon » Mon Feb 18, 2019 7:31 pm
Awesome. Hopefully it fixes this disc, and Crouching Tiger. My 2 last discs that I cannot make a backup of.
