Cannot open Bohemian Rhapsody UHD
slongmire
Post by slongmire » Tue Feb 12, 2019 10:51 pm
MakeMKV v1.14.2 win(x64-release) started
Using LibreDrive mode (v04 id=6F4CB5E20C3C)
Saved AACS dump file as C:\Users\longmire/.MakeMKV/MKB20_v66_Bohemian_Rhapsody_0F5C.tgz
So, am I supposed to send the .tgz file to you or do I just have to wait until the next round of hashkeys.txt comes out? I did download Hashkeys.txt today 2-12-2019.
Re: Cannot open Bohemian Rhapsody UHD
Post by d00zah » Tue Feb 12, 2019 11:07 pm
Yes, dump should be sent to svq@makemkv.com .
BTW it is no longer necessary to manually download the key file. I has been automatic for a few MakeMKV versions now (as long as 'Allow contacting web server...' is checked in General prefs tab),
bmillham
Post by bmillham » Wed Feb 13, 2019 4:03 am
I just got home from work with my new copy of BR UHD, and it opened and is ripping fine. That was a quick update :D
stuckinkodiagain
Post by stuckinkodiagain » Wed Feb 13, 2019 4:49 am
bmillham wrote: Wed Feb 13, 2019 4:03 am I just got home from work with my new copy of BR UHD, and it opened and is ripping fine. That was a quick update :D
Does not rip for me tonight using the latest version of MakeMKV (1.14.2) and connected to the internet. My copy was purchased from Amazon; where was yours?
Regardless, dump file has been submitted to svq@makemkv.com. Thanks to the developers, as always!
bmillham
Post by bmillham » Wed Feb 13, 2019 6:47 pm
stuckinkodiagain wrote: Wed Feb 13, 2019 4:49 am
Mine was purchased at Walmart.
bobtimms
Post by bobtimms » Thu Feb 14, 2019 7:39 pm
Can't open my copy purchased from VUDU which is supplied by Walmart. Using MakeMKV v1.14.2 .
Dump file has been submitted to svq@makemkv.com.
Blauman
Post by Blauman » Sat Feb 16, 2019 1:48 am
Ripping mine as I type this. Disc purchased from Best Buy on Tuesday.
slongmire
Post by slongmire » Sat Feb 16, 2019 2:04 am
Purchased via Amazon - Ripped successfully this evening - Watching it now on my LG OLED - THANKS for rapid key replacement!
averageschmoe
Post by averageschmoe » Tue Feb 19, 2019 1:58 am
I also can not open Bohemian Rhaspody. I'm using a registered version of MakeMKV on Ubuntu and everything is up-to-date and MakeMKV is allowed to contact the server, I even manually downloaded the keys-hashed.txt file when nothing else worked and still am unsuccessful. When I open the txt file I don't see an entry for the movie. Any suggestions?
jayper
Post by jayper » Thu Feb 21, 2019 8:25 pm
Worked for me this morning. Worth giving it another shot now.
Thanks so much!
bobtimms
Post by bobtimms » Thu Feb 21, 2019 10:03 pm
Mine worked today too. Thanks Mike😃
mfraz74
Post by mfraz74 » Tue Nov 12, 2019 10:28 pm
Received Bohemian Rhapsody UHD as a promo from Sony - it has "For promotional use only not for resale" and MakeMKV won't open it.
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Saved AACS dump file as /home/mfraser/.MakeMKV/MKB20_v66_Bohemian_Rhapsody_7FB7.tgz
st4evr
Post by st4evr » Tue Nov 12, 2019 11:36 pm
mfraz74 wrote: Tue Nov 12, 2019 10:28 pm Received Bohemian Rhapsody UHD as a promo from Sony - it has "For promotional use only not for resale" and MakeMKV won't open it.
Did you submit the dump file as it has been discussed and advised many times over?
https://www.makemkv.com/forum/search.ph ... +this+disc
Including in the posts above of this very thread.
mfraz74
Post by mfraz74 » Mon Dec 09, 2019 10:46 pm
st4evr wrote: Tue Nov 12, 2019 11:36 pm
Yes, I did and the following day the disc could be read without issues.
