MakeMKV made awesome file, but can't stream it???
JinxCanada
Re: MakeMKV made awesome file, but can't stream it???
#16 Post by JinxCanada » Sun Aug 15, 2010 4:55 am
General
Complete name : I:\Gladiator 1080P DTS-MA\Gladiator DTS-MA.mkv
Format : Matroska
File size : 32.9 GiB
Duration : 2h 50mn
Overall bit rate : 27.5 Mbps
Encoded date : UTC 2010-08-14 20:03:56
Writing application : MakeMKV v1.5.8 win(x64-release)
Writing library : libmakemkv v1.5.8 (0.7.7/0.8.1) win(x64-release)
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 50mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA
Codec ID : A_DTS
Duration : 2h 50mn
Bit rate mode : Variable
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Title : HD Lossless
Language : English
Menu
00:00:00.000 : en:Chapter 00
00:07:14.308 : en:Chapter 01
00:12:51.103 : en:Chapter 02
00:18:45.791 : en:Chapter 03
00:23:30.325 : en:Chapter 04
00:32:59.394 : en:Chapter 05
00:37:35.878 : en:Chapter 06
00:40:51.740 : en:Chapter 07
00:47:33.725 : en:Chapter 08
00:51:36.843 : en:Chapter 09
00:55:45.383 : en:Chapter 10
01:02:22.280 : en:Chapter 11
01:09:57.985 : en:Chapter 12
01:19:09.286 : en:Chapter 13
01:29:22.648 : en:Chapter 14
01:37:12.785 : en:Chapter 15
01:41:36.798 : en:Chapter 16
01:51:59.837 : en:Chapter 17
01:56:37.281 : en:Chapter 18
02:00:44.487 : en:Chapter 19
02:04:43.225 : en:Chapter 20
02:12:20.015 : en:Chapter 21
02:13:33.588 : en:Chapter 22
02:24:16.439 : en:Chapter 23
02:28:49.670 : en:Chapter 24
02:34:21.752 : en:Chapter 25
02:38:44.556 : en:Chapter 26
02:42:58.727 : en:Chapter 27
JinxCanada
#17 Post by JinxCanada » Sun Aug 15, 2010 4:56 am
does that help at all?
skittle
#18 Post by skittle » Sun Aug 15, 2010 4:56 am
I would bet if you uncheck all subtitles, it will work.
*edit* well it looks like there are no subtitles in the mkv, so that is not the problem.
Does ps3mediaserver have a logging function?
JinxCanada
#19 Post by JinxCanada » Sun Aug 15, 2010 4:57 am
here's the info for Avatar
General
Complete name : I:\Avatar DTS 1080P\title00.mkv
Format : Matroska
File size : 34.3 GiB
Duration : 2h 41mn
Overall bit rate : 30.3 Mbps
Encoded date : UTC 2010-08-14 23:30:18
Video
Format : AVC
Format settings, ReFrames : 2 frames
Duration : 2h 41mn
Bit rate : 28.2 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.568
Stream size : 31.9 GiB (93%)
Audio
Format : DTS
Codec ID : A_DTS
Duration : 2h 41mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Bit depth : 24 bits
Video delay : -9ms
Stream size : 1.71 GiB (5%)
Title : 3/2+1
Language : English
Text
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Menu
00:06:17.960 : en:Chapter 01
00:07:53.598 : en:Chapter 02
00:12:04.890 : en:Chapter 03
00:14:00.464 : en:Chapter 04
00:20:00.574 : en:Chapter 05
00:24:00.230 : en:Chapter 06
00:26:53.278 : en:Chapter 07
00:31:41.899 : en:Chapter 08
00:33:33.428 : en:Chapter 09
00:35:43.849 : en:Chapter 10
00:43:31.859 : en:Chapter 11
00:49:23.627 : en:Chapter 12
00:54:29.974 : en:Chapter 13
00:59:56.050 : en:Chapter 14
01:05:10.197 : en:Chapter 15
01:11:36.417 : en:Chapter 16
01:15:11.006 : en:Chapter 17
01:20:29.115 : en:Chapter 18
01:24:41.910 : en:Chapter 19
01:36:04.800 : en:Chapter 20
01:37:55.786 : en:Chapter 21
01:44:33.099 : en:Chapter 22
01:48:15.488 : en:Chapter 23
01:53:53.868 : en:Chapter 24
01:55:32.884 : en:Chapter 25
01:58:38.819 : en:Chapter 26
02:02:05.568 : en:Chapter 27
02:05:33.859 : en:Chapter 28
02:10:01.835 : en:Chapter 29
02:16:07.283 : en:Chapter 30
02:19:50.840 : en:Chapter 31
02:25:50.324 : en:Chapter 32
02:31:14.064 : en:Chapter 33
02:35:05.295 : en:Chapter 34
02:41:40.690 : en:Chapter 35
JinxCanada
#20 Post by JinxCanada » Sun Aug 15, 2010 4:57 am
skittle wrote:I would bet if you uncheck all subtitles, it will work.
ok. well i'm ripping a movie now with NO subtitles..i'll report back in about 35min. stick around and you'll have your answer. if that's it...i OWE YOU BIG TIME!
however, it will suck to rip a BD that NEED subtitles in certain areas and not be able to get them. is there any work around for that? i'm thinking of Avatar for example
JinxCanada
#21 Post by JinxCanada » Sun Aug 15, 2010 5:01 am
checking to see if JAVA has anything to do with this. updating now
JinxCanada
#22 Post by JinxCanada » Sun Aug 15, 2010 5:02 am
this info was in PS3 MS..I dunno if this has the answer or not...but again, all the MKV bd rips i download stream just fine???
4. I've got a black screen or "unsupported data" message when I launch a transcoded video file
4.1 with MEncoder alone
If this is happening with Mencoder, the culprit would be most likely the inter communication process between java and mencoder, as
Mplayer/Mencoder is a great app who takes virtually anything you throw at it. So, either your video must be really messed up,
or there's a bug or a wrong configuration/incompatibility with your system. In both cases, looking at the debug.log file is the only solution.
4.2 with AviSynth/MEncoder
You can first check if the video is playing in Windows Media Player / Media Player Classic. If yes, maybe you are
using some srt/sub subtitles files and haven't installed VobSub (the VSfilter.dll must be in the path, elsewhere you can copy it in the
AviSynth plugins folders). If this is not the case, you obviously met a bug, see question 3.1.
4.3 with tsMuxer
tsMuxer has not a large codec type support on PS3. It accepts AVC/H264, MPEG2, MP2, AC3, PCM codecs and MPG, TS, M2TS, MKV as input.
Also, H264 encoded with level 5 or exotic settings (reduce to Level 4.1 is just a header change, with no success garanty)
will not play on the PS3, hence your black screen maybe.
JinxCanada
#23 Post by JinxCanada » Sun Aug 15, 2010 5:04 am
i'm going for a smoke...brb :mrgreen: :mrgreen: :mrgreen: :mrgreen:
skittle
#24 Post by skittle » Sun Aug 15, 2010 5:05 am
edit*
JinxCanada
#25 Post by JinxCanada » Sun Aug 15, 2010 5:06 am
here is the INFO of an MKV BD rip that DOES play fine streaming in PS3 Media Server....
General
Complete name : F:\1080P BluRay Movies\9 BluRay 1080P\9.2009.1080p.BluRay.DTS.x264-EbP\9.2009.1080p.BluRay.DTS.x264-EbP.mkv
Format : Matroska
File size : 5.83 GiB
Duration : 1h 19mn
Overall bit rate : 10.5 Mbps
Encoded date : UTC 2009-11-20 12:56:52
Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.0
Muxing mode : Container profile=Unknown@4.0
Duration : 1h 19mn
Bit rate : 9 029 Kbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.182
Stream size : 4.88 GiB (84%)
Title : 9 (2009)
Writing library : x264 core 79 r1342 e8501ef
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=0.7:0.2 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-3 / threads=8 / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / mbtree=0 / bitrate=9029 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.60
Language : English
Audio
Format : DTS
Codec ID : A_DTS
Duration : 1h 19mn
Bit depth : 24 bits
Stream size : 856 MiB (14%)
Title : DTS 5.1 @ 1.5 Mbps
Language : English
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Vietnamese
Text #2
Format : UTF-8
Language : English
Text #3
Format : UTF-8
Language : Czech
Text #4
Format : UTF-8
Language : Danish
Text #5
Format : UTF-8
Language : Finnish
Text #6
Format : UTF-8
Language : Greek
Text #7
Format : UTF-8
Language : Hungarian
Text #8
Format : UTF-8
Language : Norwegian
Text #9
Format : UTF-8
Language : Polish
Text #10
Format : UTF-8
Language : Portuguese
Text #11
Format : UTF-8
Language : Romanian
Text #12
Format : UTF-8
Language : Spanish
Text #13
Format : UTF-8
Language : Swedish
Menu
00:00:00.000 : en:00:00:00.000
00:05:00.000 : en:00:05:00.000
00:10:00.000 : en:00:10:00.000
00:15:00.000 : en:00:15:00.000
00:20:00.000 : en:00:20:00.000
00:25:00.000 : en:00:25:00.000
00:30:00.000 : en:00:30:00.000
00:35:00.000 : en:00:35:00.000
00:40:00.000 : en:00:40:00.000
00:45:00.000 : en:00:45:00.000
00:50:00.000 : en:00:50:00.000
00:55:00.000 : en:00:55:00.000
01:00:00.000 : en:01:00:00.000
01:05:00.000 : en:01:05:00.000
01:10:00.000 : en:01:10:00.000
01:15:00.000 : en:01:15:00.000
JinxCanada
#26 Post by JinxCanada » Sun Aug 15, 2010 5:08 am
and THE BOOK OF ELI which also streams no problem.
General
Complete name : F:\1080P BluRay Movies\Book Of Eli 1080P\The.Book.of.Eli.2010.1080p.Bluray.DTS.x264-ESiR\The.Book.of.Eli.2010.1080p.Bluray.DTS.x264-ESiR.mkv
Format : Matroska
File size : 7.40 GiB
Duration : 1h 57mn
Overall bit rate : 9 009 Kbps
Encoded date : UTC 2010-06-01 19:59:19
Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Video
Format : AVC
Format settings, ReFrames : 3 frames
Duration : 1h 57mn
Bit rate : 7 500 Kbps
Height : 800 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.204
Stream size : 6.01 GiB (81%)
Writing library : x264 core 96 r1613 81e75e9
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=esa / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=0 / bitrate=7500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.70 / nal_hrd=none
Language : English
Audio
Format : DTS
Codec ID : A_DTS
Duration : 1h 57mn
Bit depth : 24 bits
Stream size : 1.24 GiB (17%)
Language : English
Text #1
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Language : English
Text #2
Format : ASS
Language : Finnish
Text #3
Format : ASS
Language : Greek
Text #4
Format : ASS
Language : Swedish
Text #5
Format : ASS
skittle
#27 Post by skittle » Sun Aug 15, 2010 5:14 am
Well, all that you can try now is to use only the lossy DTS and Video stream in the mkv (this is the only difference between yours and the ones that do work), no DTS-MA, no subs. If that doesnt work, you might have to ask the ps3mediaserver dev, because they should definitely work as thats one of PMS's main function! (ie AVC+DTS in MKV -> TS)
No support for PGS/SUP subtitiles and DTS-MA would not be surprising
JinxCanada
#28 Post by JinxCanada » Sun Aug 15, 2010 5:27 am
skittle wrote:Well, all that you can try now is to use only the lossy DTS and Video stream in the mkv (this is the only difference between yours and the ones that do work), no DTS-MA, no subs. If that doesnt work, you might have to ask the ps3mediaserver dev, because they should definitely work as thats one of PMS's main function! (ie AVC+DTS in MKV -> TS)
just finished a new rip with ONLY DTS lossy and NO sub titles at all...i'll go try right now.
well..it still won't stream to the PS3. I dunno wtf is going on..but i was SURE this was the place to get the answers. i'll be waiting for any further help anyone can give. TIA
btw AVC?
skittle
#29 Post by skittle » Sun Aug 15, 2010 5:59 am
AVC is another name for H.264
JinxCanada
#30 Post by JinxCanada » Sun Aug 15, 2010 2:56 pm
well guys i'm still having problems....so ANY help would be appreciated!!!
