Robin Hood (2018) playlist obfuscation
taseldor
Post by taseldor »
Anyone have any idea which one is the right one? Thank you!
Steveredrum
Re: Robin Hood (2018) playlist obfuscation
Post by Steveredrum »
Yes the the correct PLAYLIST please no sign of it anywhere else on the net
Found And Tested For Retail (U.S.A) its - [00610.MPLS]
hvnphoto
Post by hvnphoto »
US Retail
Title information
Source file name: 00610.mpls
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Segment map: 512,503,511,505,508,515,509,514,507,510,513,502,506,501,504
File name: Robin Hood_t105.mkv
taseldor
Post by taseldor »
Steveredrum wrote:
Sat Feb 16, 2019 11:03 am
Thank you!
book1
Post by book1 »
Any other avenues tested?
Vanorie
Post by Vanorie »
I did not have the above file. This is the one that worked for me.
Title information
Source file name: 00855.mpls
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Segment map: 502,512,501,506,514,515,505,510,504,511,508,503,513,509,507
File name: Robin Hood_t299.mkv
WAYFLIX
Post by WAYFLIX »
Vanorie wrote:
Tue Feb 19, 2019 11:34 am
Title information
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Is that Redbox??
killakel77
Post by killakel77 »
WAYFLIX wrote:
Tue Feb 19, 2019 2:42 pm
Title information
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Is that Redbox??
This is the correct mpls for Redbox version. I did a side by side comparison to confirm.
WAYFLIX
Post by WAYFLIX »
killakel77 wrote:
Tue Feb 19, 2019 3:15 pm
Title information
Duration: 1:56:08
Chapters count: 16
Segment count: 15
Is that Redbox??
dp5081
Post by dp5081 »
i found that the file name comes up as Robin Hood_t309.mkv. it has the same Segment Map as what is posted with the 299.mkv
MSDowney
Post by MSDowney »
Thank you guys. I just got on here looking for this.
DBond
Post by DBond »
Does anybody know the playlist for the Canadian version? My segment maps all start with 513.
MAJWoody
Post by MAJWoody »
Weird, I get the same segment map:
But the file name I get is t297.mkv
Anyone know what this is all about?
Title numbering is done for titles that are at least as long as your minimum title length (MTL). Someone with 1800 seconds set for MTL will have a different numbering than someone with MTL 1 second, or even the default 120.
The important thing to look at is the "Source file name", which you will see in the Info window when you highlight a title.
MAJWoody
Post by MAJWoody »
Gotcha... thanks Woodstock.... so, I am assuming that most here in the forum have their MTL set to the same number. Is this true and if so, what is the number?
Thanks in advance-
MAJWoody
