Firmware downgrade using official (patched) flasher, the "Ultra hax0r guide"
Locked
bfrink
Re: Firmware downgrade using official (patched) flasher, the "Ultra hax0r guide"
#61 Post by bfrink » Wed Feb 13, 2019 3:59 pm
Thanks MartyMcNuts your ASUS ODD FW 3.02 Updater for BW-16D1HT (Patched) worked like a charm on my BW-16D1HT and Vantec NST-536S3-BK on Windows 7.
#62 Post by MartyMcNuts » Wed Feb 13, 2019 10:47 pm
bfrink wrote: Wed Feb 13, 2019 3:59 pm Thanks MartyMcNuts your ASUS ODD FW 3.02 Updater for BW-16D1HT (Patched) worked like a charm on my BW-16D1HT and Vantec NST-536S3-BK on Windows 7.
You're welcome! Cheers..
Kaphotics
#63 Post by Kaphotics » Thu Feb 14, 2019 7:24 am
Just picked up a bu40n with firmware 1.2.0. Anyway to downgrade or cross flash this drive?
#64 Post by Billycar11 » Thu Feb 14, 2019 10:26 pm
Kaphotics wrote: Thu Feb 14, 2019 7:24 am Just picked up a bu40n with firmware 1.2.0. Anyway to downgrade or cross flash this drive?
my post on first page do not crossflash that drive only put it to bu40n 1.00
Kaphotics
#65 Post by Kaphotics » Fri Feb 15, 2019 5:26 am
Billycar11 wrote: Thu Feb 14, 2019 10:26 pm
Thanks a lot, it worked.
#66 Post by Billycar11 » Fri Feb 15, 2019 9:52 am
How to video is up 3rd post and here to https://www.youtube.com/watch?v=Yfpf6HoMMis
#67 Post by MartyMcNuts » Sun Feb 17, 2019 12:21 pm
Hi everyone,
I've given us another option for flashing our drives. I have modified the ASUS flasher tool to allow us to flash / cross-flash any UHD friendly firmware to out drives.
Check out thread titled: NEW OPTION: 'UHD Friendly' Firmware Downgrade Using Official (Modified) ASUS Flasher
or here is the link
viewtopic.php?f=16&t=18933
Cheers!
DAlba
#68 Post by DAlba » Tue Feb 19, 2019 4:21 pm
How do I flash LG WH16NS60 via USB? I tried the tool posted at top of first page but it says No ATAPI device found. Please advise
#69 Post by Billycar11 » Tue Feb 19, 2019 7:09 pm
DAlba wrote: Tue Feb 19, 2019 4:21 pm How do I flash LG WH16NS60 via USB? I tried the tool posted at top of first page but it says No ATAPI device found. Please advise
Does you drive read disks in your USB to sata device not all USB to sata devices support optical disk drives they need atapi support
DAlba
#70 Post by DAlba » Tue Feb 19, 2019 7:49 pm
Yes. Replaced my existing LG drive WH15S40. I was on Windows XP. Trying now with Windows 8 and it started but been at 0% for over 2 min. Not sure what to do now
cholla
#71 Post by cholla » Wed Feb 20, 2019 6:28 pm
Billycar11 wrote: Tue Feb 19, 2019 7:09 pm
My Vantec NST-536S3-BK USB enclosure has a WH16NS40 NS50 drive.
It reads UHD blu ray discs.
I flashed the firmware with the old method from an older computer that could do this.
I don't plan to flash this working drive with the new program via USB.
I just wanted to let you know this enclosure at least reads the optical discs.
I did go as far as testing the new program for flashing with this enclosure plugged in & the WH16NS40 NS50 drive was detected.
That is as far as I plan to test.
spl147
#72 Post by spl147 » Thu Feb 21, 2019 2:25 pm
is there a BU50N firmware that works with MakeMKV yet?
spl147
#73 Post by spl147 » Thu Feb 21, 2019 2:31 pm
has anyone seen this error using the patched flasher and DE firmware?
it's a BU40N on 1.01 manufactuer date 09/18, even though i got the error it still downgraded and works fine
nj54567
#74 Post by nj54567 » Sun Feb 24, 2019 9:42 am
MartyMcNuts wrote: Thu Feb 07, 2019 12:22 am @MaDMaX @Captain Ron,
As @SamuriHL said, I have patched the official ASUS 3.02 Updater (see last post of page 1) so that is all that you need to downgrade a BW-16D1HT from 3.03 to 3.02, even via USB.
This makes it a hell of a lot easier!!!
@MartyMcNuts / @ Billycar11
First, thank you so much for creating the Firmware downgrade tool and YT video for Asus BW-16D1HT. Amazing work!
Whenever I run your tool to downgrade, I first get the following error pop up:
Error Text:
"DeviceIoControl Error: Error Code 21
I can't issue Command throug0h SPTI"
<<OK>>
I took a chance (hugh risk) and clicked OK and the usual Firmware Downgrade window showed up next and proceeded with the suggested step. It downgraded the firmware to 3.0.2. However, I wonder why I aways get this error message when I run the program. Pls let me know if you know the reason. Thanks.
The drive is in the Vantec NexStar DX USB 3.0 enclosure connected to Win10 laptop through USB 3.0 port.
#75 Post by MartyMcNuts » Sun Feb 24, 2019 9:56 pm
@nj54567,
I think it has something to do with the Vantec enclosure not wanting to pass all commands through to the drive. I'm pretty sure other people have had a similar issue with Vantec enclosures.
Locked
