Unfortunately you cannot play .m2ts file in DV. I have just tried on Sony X700 and it played in HDR10Grencola wrote: Fri Feb 08, 2019 5:58 am your dv mp4 looks to have been converted properly. It seems to be a Vizio issue with certain models, particularly the f1's (latest) as the e0's work fine. the pq65-f1 doesn't trigger dv, yet the m65-e0 works perfectly. Vizio tech support is working on it, as they are able to recreate the issue now, so I'll let you know when I get an update. however, for less than $200, we hooked up a Sony x700 uhd bd player to the pq65-f1 and it played both .mp4 in DV as well as the large .m2ts file (from the bdmv/streams folder of your backed up uhd disc) in DV. The .m2ts is better for sound as you get full hd-audio + atmos (with a 2nd hdmi out port for legacy AVRs), where as the .mp4 is lossy eac3 audio at best and requires demuxing / converting / remuxing. 3 confirmed Cinavia affected movies were tested using both formats from usb and dlna, and neither of them had playback stopped either, so hopefully that's not an issue (more testing is still required)![]()
Note that when you turn on DV in settings, even HDR10 video shows on a TV as DV.
