Makemkv 1.14.2 with Kodi 18.0 or VLC 3.0
dgktkr
Post by dgktkr »
On my Ubuntu 18.04 system blurays without BD+ would play without issue with unmodified Makemkv 1.14.2, but discs with BD+ protection would fail.
There have been some changes to Makemkv since 1.12 that accommodate the libbluray API for aacs decryption. Unfortunately, the changes didn't go as far as fixing things for BD+ discs.
A solution isn't difficult. Before you build Makemkv 1.14.2, modify the source files according to steps 5 through 7 in this post viewtopic.php?t=16824#p61608
That's what got bluray discs playing again for me. Hopefully it'll work for you too.
dgktkr
PS Don't use snap to install VLC; it forces VLC to use open source versions of libaacs and libbdplus.
