Problems Backing-up Big
jbgdbg
Post by jbgdbg » Sun Feb 10, 2019 3:52 pm
Hello All,
I am having issues backing up my blu-ray disk BIG. I keeping getting Scsi errors. I have tried following the directions for Scsi errors with no success. I'm new to the forum and have tried looking for previous post on this but didn't find any. If I missed it, I'm sorry! please point me in the right direction. Any help would be appreciated!
Thanks,
Joe
Re: Problems Backing-up Big
Post by Woodstock » Sun Feb 10, 2019 4:36 pm
Knowing WHAT SCSI errors you are getting is key to figuring out WHY you're getting them.
Do you have debug logging turned on (FAQ link in my signature) ? Please post the log from trying to rip BIG as part of your reply.
jbgdbg
Post by jbgdbg » Sun Feb 10, 2019 6:25 pm
I will run it again and make sure debug is on.
jbgdbg
Post by jbgdbg » Mon Feb 11, 2019 10:52 pm
Well Guys, Thank you in advance. I ran Big again. This time a had debug on. So far I am only have problems with this blu-ray. I have backed up around 200 DVD and Blu-rays. About 10 sense the start of the post. Anyway hear is the report, starting at the saving point.
Saving 1 titles into directory /Volumes/jbgdbg/Media Server
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00121.m2ts' at offset '687925248'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '687925248'
DEBUG: Code 1073741829 at oR=Y1>iTZ?NprdY6aW:29395080
DEBUG: Code 100864261 at oR=Y1>iTZ?NprdY6aW:29395080
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00121.m2ts' at offset '687992832'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '687992832'
DEBUG: Code 0 at )o^[7#n9G2L$z#ybU`mC:29395011
DEBUG: Code 0 at QXq-~p=E9 #}S?W)9NI|:29394068
DEBUG: Code 0 at )o^[7#n9G2L$z#ybU`mC:29394459
DEBUG: Code 335934 at )o^[7#n9G2L$z#ybU`mC:29393286
DEBUG: Code 0 at "O@}W`.ZWi2muU=C9/=\I:213136608
DEBUG: Code 0 at 66AO3<:sL"B-bW4-D/]#:29394022
DEBUG: Code 0 at 66AO3<:sL"B-bW4-D/]#:213140840
DEBUG: Code 0 at 66AO3<:sL"B-bW4-D/]#:29404556
DEBUG: Code 0 at 66AO3<:sL"B-bW4-D/]#:213139506
DEBUG: Code 0 at \8{QS"5#OFT<aB#[:29395908
DEBUG: Code 0 at Fx\oI]lUf#vc-[vhe:213132698
DEBUG: Code 0 at Fx\oI]lUf#vc-[vhe:213132146
DEBUG: Code 0 at Fx\oI]lUf#vc-[vhe:29393769
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 4 to file /Volumes/jbgdbg/Media Server/Big_t04.mkv
Encountered 22 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Post by Woodstock » Mon Feb 11, 2019 11:37 pm
Two possibilities.
Given the errors, you're probably using a USB-powered drive. It is quite common for USB drives to run out of power (not enough power from the port they're plugged into) when the ripping speed gets too fast. The drive shuts down, then the operating system says it can't talk to it, the drive resets and things look normal. Ultimate fix is to give the drive enough power (use a powered USB hub, sometimes a double-headed cable is required), but you can also slow the rip down by writing to a USB flash drive instead of the hard disk. Just make sure the flash drive is big enough and formatted either in ExFAT (for Mac) or NTFS (Windows).
The other way these errors can pop up is with a drive that "tries too hard" to recover data. Rather than say, "There is an error here", the drive just keeps on trying to read the disk, ignoring the operating system, when then gives error messages that the drive isn't responding. Often just cleaning the disk takes care of these issues.
BIG is rippable - I've done it.
jbgdbg
Post by jbgdbg » Tue Feb 12, 2019 12:13 am
Hi Woodstock,
Thanks for getting back to me. I have tried cleaning the disk. I haven't checked to see if it is playable for a while. Because I have ripped so many others I would not have thought it was a power problem, but that is what I was reading into it also. I tried slowing it down by plugging it into a usb 2.0 with no luck. I can try getting a powered hub and cleaning the disk again.
Thanks again
Post by Woodstock » Tue Feb 12, 2019 1:56 am
If it's the USB power, plugging into USB2 isn't going to fix the issue. USB2 is more than fast enough to absorb the data coming off the optical disk at the maximum speed of the drive... but the drive takes more power the faster it spins.
Depending on the drive, the port(s) you plug into must be able to supply a "full unit" of USB power, i.e., .5 amp at 5v. Some drives need "2 units", 1.0 amp at 5v, which means plugging into two fully-powered USB ports. A typical un-powered hub takes 1 unit of USB power and splits it among the attached devices. That's fine when the device doesn't need a lot of power, but not when it does.
Using a USB flash drive slows the rate that the data can be written, which will force the drive to slow down, and keeps it within the available power budget.
