Azur et Asmar: main cartoon only provides sound, not picture
haioun
Post by haioun »
With MakeMKV 1.5.7, the main file is only playing sound, but no picture. Did anyone could display it properly (data encryption is AACS 9...)
Re: Azur et Asmar: main cartoon only provides sound, not pic
Post by mike admin »
You can use VLC player to play such file on OS X
haioun
Post by haioun »
I use VLC, but only get a sound file. The picture must be saved given the size of the file but not displayed (I use the latest version of VLC?
setarip_old
Post by setarip_old »
Hi!
Open tsMuxeR and drag and drop the main movie .M2TS onto it, then post all of the information from the tsMuxeR bottom window back here...
haioun
Post by haioun »
thank you, but can you be more explicit? I do not have such a folder on the blu-ray: the structure is as follows:
AACS
BDMV
CERTIFICATE
and BDMV is made of:
AUXDATA
BACKUP
BDJO
CLIPINF
index.bdmv
JAR
META
MovieObject.bdmv
PLAYLIST
STREAM
setarip_old
You'll find all of the .M2TS files in the "Stream" sub-folder (The largest .M2TS file is usually the main movie)...
