Update: slim drives are happening! BU40Ns get them here.
Ask me for a 4K “UHD Friendly” Blu Ray drive to try before you buy!
Help Finding an Slim ODD
jonghotti
Re: Help Finding an Slim ODD
so i take it my BU40N file works?jonghotti wrote: Sat Feb 09, 2019 7:30 am Update: slim drives are happening! BU40Ns get them here
jonghotti
You wrote the firmware for the BU40N slim drive? Quite an accomplishment.
josepr
So it works?jonghotti wrote: Sat Feb 09, 2019 7:30 am Update: slim drives are happening! BU40Ns get them here.IMG_1683.jpg
Also what speed are you it perform compared to a driver like wh14ns40 and wh16ns40
I enabled the downgrade on the 1.00 one here: viewtopic.php?f=16&t=18873jonghotti wrote: Sat Feb 09, 2019 10:41 am You wrote the firmware for the BU40N slim drive? Quite an accomplishment.
jonghotti
I grabbed all the firmware files from doozah and off the myce boards like 6 months ago. But thank you none the less!Billycar11 wrote: Sat Feb 09, 2019 6:27 pmI enabled the downgrade on the 1.00 one here: viewtopic.php?f=16&t=18873jonghotti wrote: Sat Feb 09, 2019 10:41 am You wrote the firmware for the BU40N slim drive? Quite an accomplishment.
jonghotti
the BU40N with this firmware goes up to 6.0X and stays there, pegged, it's like it want's to go faster but something is throttling it back, it' s wild, even between files it's still chugging along at 6x. These little things are badass.josepr wrote: Sat Feb 09, 2019 3:37 pmSo it works?jonghotti wrote: Sat Feb 09, 2019 7:30 am Update: slim drives are happening! BU40Ns get them here.IMG_1683.jpg
your still doing it with dosflash? this way viewtopic.php?f=16&t=18873#p70308 is so much easier and safer you dont chance slightly corrupt cal data because it uses lgs official tooljonghotti wrote: Sat Feb 09, 2019 8:03 pmI grabbed all the firmware files from doozah and off the myce boards like 6 months ago. But thank you none the less!Billycar11 wrote: Sat Feb 09, 2019 6:27 pmI enabled the downgrade on the 1.00 one here: viewtopic.php?f=16&t=18873jonghotti wrote: Sat Feb 09, 2019 10:41 am You wrote the firmware for the BU40N slim drive? Quite an accomplishment.
jonghotti
I’ve been using the LG tool for awhile.
well why didnt you tell us how to enable downgrades all that time ago to get around Write DRAM NG 05/24/00 we are a community
jonghotti
Well probably because I've no idea what you're talking about. And I'm not going to comment on the we are a community bit, I'd love to, but I've no use for drama right now.Billycar11 wrote: Sat Feb 09, 2019 8:44 pmwell why didnt you tell us how to enable downgrades all that time ago to get around Write DRAM NG 05/24/00 we are a community
I've been offering up the WH16NS60 for quite a fucking while but no one has shown an interest until now. The tools are out there, just gotta go get em.
there is no drama it was sarcasm im just trying to say you can now go from ns60 1.01 to 1.00 and all other downgrades too with no data mover tool or dosflash. so unless you have been doing it a different way all along that does not use dos flash or the unlocked flasher.jonghotti wrote: Sat Feb 09, 2019 9:59 pm
jonghotti
There is an lg flasher hard coded to crossflash a wh16ns60 to asus and one that downgrades it from 1.01 to 1.00
Most of the time I prefer the unlocked dos flasher. If it ain’t broke don’t fix it
never seen those flashers before wonder if they knew about this the whole time changing ff to de im going to look for those see if they do it the same way thanks.jonghotti wrote: Sat Feb 09, 2019 11:28 pm There is an lg flasher hard coded to crossflash a wh16ns60 to asus and one that downgrades it from 1.01 to 1.00
jonghotti
The crossflasher is found on myce search wh16ns60 but the one that downgrades 1.01 to 1.00 don’t remember where that is.
To be entirely honest I may have had a support call with LG who I shared my screen with and he remoted in and used the tool - and no did not leave a copy.
When you’ve got 300 optical drives registered with LG they’re a little nicer on the support call.
