Last version 1.14.2 not work.
MGPegasus
Post by MGPegasus » Mon Feb 04, 2019 7:30 pm
Last version 1.14.2 not work. The program tell: NSIS Error installero integrità check has failed. Common cause damage media or incomplete download. Cobtact the installero for new copy. Information at: http://nsis.sf.net/NSIS_Error. File download Ok. Tell me for solution. Thanks.
Re: Last version 1.14.2 not work.
Post by Woodstock » Mon Feb 04, 2019 7:42 pm
Most likely cause is either a corrupted download, or your antivirus software is interfering.
MakeMKV has code in it to contact this server to look for updates. Microsoft and a few other AV vendors periodically decide that it is "unsafe", and move parts of the install program to their "virus vault", meaning it isn't there when the installer tries to run it.
aprosak
Post by aprosak » Thu Feb 07, 2019 5:01 am
I'm having the same problem with 1.14.2, nothing has worked since it was installed. I'm using Windows Defender and it hasn't indicated anything was detected.
Mtenga
Post by Mtenga » Thu Feb 07, 2019 6:16 pm
Yes something definitely up. I managed to rip a bluray and DVD OK but was getting this message on startup of the program:
LibreDrive firmware support is not yet available for this drive (id=F8B3C9080B22)
My 4K friendly drive would not open the Mission Impossible Fallout UHD disk. So I re-downloaded the program and it now seems to be working with that disc but sluggishly.
aprosak
Post by aprosak » Thu Feb 07, 2019 7:43 pm
I've deleted and reinstalled it numerous times. I get several errors, or sometimes nothing at all and the disc just spins and spins and spins.
Dlleno
Post by Dlleno » Sat Feb 09, 2019 4:25 am
I also have fallout, and a stock lg drive with 1.0 firmware on its way from Alex. This is a Dolby vision disk! How will that rip and what happens if there is no DV capability in the playback chain? Roku ultra doesn't support vision. My Samsung uhd tv won't support vision either cause sammy is still throwing a fit and won't pay homage to dolby .
So how will this title look on my TV?
Post by Billycar11 » Sat Feb 09, 2019 4:31 am
i think it just drops back to hdr 10 not sure though
Dlleno
Post by Dlleno » Sat Feb 09, 2019 4:44 am
Plausible! So will this one stream via roku and play on a hdr10 tv?
Post by SamuriHL » Sat Feb 09, 2019 4:45 am
If you're ripping to MKV it won't store the DV track anyway, so, yes, it'll default to HDR10 which is good for the equipment you have.
Post by Billycar11 » Sat Feb 09, 2019 4:47 am
i think so if the roku does 4k hdr but not 100% sure
Dlleno
Post by Dlleno » Sat Feb 09, 2019 4:49 am
Ok that makes sense thanks. Vision must be yet another challenge for Mike
Post by SamuriHL » Sat Feb 09, 2019 4:52 am
Not really. There's nothing Mike can really do about it. MKV doesn't have a spec for Dolby Vision. If that ever changes then ripping the second video track (the Dolby Vision track) and adding it to the MKV would be possible. But, I haven't seen anything that suggests that's coming any time soon. And everything in the chain would have to support that version of the MKV spec. Also not super likely any time soon. If you want Dolby Vision there's a thread in the UHD Disc section that talks about putting it in an MP4 container, however, there are drawbacks to that around what kind of audio you can stick in an MP4 container.
Post by Billycar11 » Sat Feb 09, 2019 4:52 am
vision is not supported in .mkv format but if you do a full disk backup and use the .m2ts file that will have Dolby vision in it and will work in a player that supports m2ts files and supports Dolby vision.
its not a makemkv problem its a mkv problem
st4evr
Post by st4evr » Sun Feb 10, 2019 1:10 am
Ok you should read this:
viewtopic.php?f=12&t=17235&hilit=Vision
And educate yourself further on the matter of DV.
Dlleno
Post by Dlleno » Thu Feb 21, 2019 2:56 am
excellent. learning has occurred!
