MakeMKV broken after upgrade to Ubuntu 18.04
xr200
Re: MakeMKV broken after upgrade to Ubuntu 18.04
Post by xr200 » Thu Feb 07, 2019 2:56 pm
Nothing complicated, I'm probably using non-standard terminology.
Create a new (and therefor empty) directory, eg,
rm -rf $HOME/BUILD
mkdir $HOME/BUILD
unpack the makemkv source in $HOME/BUILD
then build it (in $HOME/BUILD)
BohunkG4mer
Post by BohunkG4mer » Wed Mar 06, 2019 12:38 am
xr200 wrote: Thu Feb 07, 2019 2:56 pm Nothing complicated, I'm probably using non-standard terminology.
rm -rf $HOME/BUILD
mkdir $HOME/BUILD
I was having the same problem and this fixed it for me. I had to start with a new directory :)
gekkentekken
Post by gekkentekken » Wed May 08, 2019 9:00 am
I had to give up eventually, but then I discovered someone had made a flatpak for it! And it solved all my problems.
https://www.flathub.org/apps/details/co ... kv.MakeMKV
pacho014
Post by pacho014 » Tue Mar 02, 2021 4:47 pm
Hi, I updated to Ubuntu 20 and experienced the exact same problem between the two codecs. How did you resolve the problem?
Post by Woodstock » Tue Mar 02, 2021 5:16 pm
The topic you replied to is old, and has nothing to do with codecs.
So, if you're having a problem with Ubuntu 20.x, you should begin a new topic and explain what your codec problem is.
