I have been encoding ghost whisperer series one but for disc 5 makemkv will ony encode title0 and title3, 1 and 2 itfails on. Is this likely to be a faulty disc as I doubt they would be using different encryption on different episodes! Below is the log file for the two it fails on.
Debug log started at Thu Aug 12 11:28:17 2010 , written by MakeMKV v1.5.8 win(x64-release)
001005:0000 MakeMKV v1.5.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Matthew/MakeMKV_log.txt
003002:0000 Calculated BUP offset does not match one in IFO header.
003033:0000 Cell 1 was discarded (structure protection?)
003019:0000 Cells 2-1 were skipped due to cell commands (structure protection?)
003033:0000 Cell 2 was discarded (structure protection?)
003019:0000 Cells 10-end were skipped due to cell commands (structure protection?)
003028:0000 Title #0 was added (7 cell(s), 0:41:56)
003028:0000 Title #2 was added (7 cell(s), 0:42:40)
003028:0000 Title #3 was added (7 cell(s), 0:40:45)
003028:0000 Title #4 was added (7 cell(s), 0:43:08)
003025:0000 Title #5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #10 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #12 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #13 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #15 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #16 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #17 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #18 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #19 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #21 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #22 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #23 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #24 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #25 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 2 titles into directory I:/TV/Ghost Whisperer/Season 01
001003:0020 DEBUG: Code 2 at 8kJmBCi*F;4g`Yps:213135251
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occured while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1717067776'
001003:0020 DEBUG: Code 0 at }&i)/,Bl1a7DLNqM:213136769
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occured while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1717100544'
001003:0020 DEBUG: Code 100864256 at }1=ipBp?g(KEt3a_1@:121263636
001003:0020 DEBUG: Code 100864256 at }1=ipBp?g(KEt3a_1@:213130007
001003:0020 DEBUG: Code 0 at F,8'XhP~=JiSm$lNbOCO:213130628
001003:0020 DEBUG: Code 0 at rqRKLouR{ SWzIg@'"_:121261704
001003:0020 DEBUG: Code 0 at F,8'XhP~=JiSm$lNbOCO:213130513
001003:0020 DEBUG: Code 838428 at F,8'XhP~=JiSm$lNbOCO:213129639
005003:0000 Failed to save title 1 to file I:/TV/Ghost Whisperer/Season 01/title01.mkv
002003:0000 Error 'Scsi error - MEDIUM ERROR:1090' occured while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '284229632'
001003:0020 DEBUG: Code 100864144 at }1=ipBp?g(KEt3a_1@:121263636
001003:0020 DEBUG: Code 100864144 at }1=ipBp?g(KEt3a_1@:213130007
001003:0020 DEBUG: Code 138784 at F,8'XhP~=JiSm$lNbOCO:213129639
005003:0000 Failed to save title 2 to file I:/TV/Ghost Whisperer/Season 01/title02.mkv
005004:0080 0 titles saved, 2 failed
005037:0204 Copy complete. 0 titles saved, 2 failed.
Possible Faulty disc
Re: Possible Faulty disc
Hi!
1) If your source material is the original, commercial DVD, try cleaning it
2) If your source material is a backup made with a program other than MakeMKV, try using your original, commercial DVD with MakeMKV instead
Hi
the source is a proper (ie I bought it) disc. I have tried cleaning it and still the same issue. I also tried to rip the wole dvd with anydvd and dvdfab and they both failed. So I guess it is damaged or something. Seems to play fine though
I'd suggest you return it to the place of purchase, in exchange for a new one...
