Collateral
RonDMC
Collateral
Post by RonDMC » Thu Aug 12, 2010 3:03 am
MakeMKV gets to 1 second remaining and just sits there and never finishes. I get the errors
DEBUG: Code 100 at Xx?t\%'u.k;,A)R.CQ8*l:213132974
If anyone can help that would be great!
Re: Collateral
Post by mike admin » Thu Aug 12, 2010 9:13 am
Is it for the latest 1.5.8 version? The problem is with some audio or subtitle track. I would ask you to figure out which particular track is at fault by selecting tracks in halves and then send MPLS and CLPI files per instructions at http://www.makemkv.com/faq/item/8/catid/6
RonDMC
Re: Collateral
Post by RonDMC » Thu Aug 12, 2010 11:06 am
Yes I am using version 1.5.8 and the problem is with the DTS-HD MA track. If I just use the core DTS and video streams it works and plays correctly. I have sent the files as requested.
Thanks for your help.
