Still having Debug code problem with Blu Rays
bicdaddy15
#1 Post by bicdaddy15 » Tue Feb 05, 2019 4:13 am
Ever since the about a week or two ago I can't get any blu ray discs to read. I've tried everything in recent posts to try and fix the problem. Here is what I am getting:
MakeMKV v1.14.2 win(x64-release) started
Downloading latest SDF to C:\Users\Curt/.MakeMKV ...
DEBUG: Code 03DF/04/ABC4C72B168F
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '1130618880'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '1250549760'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '1041537024'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '2075308032'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '1174228992'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '1122048000'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '865216512'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '878100480'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '1461872640'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '1191622656'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '0'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '6144'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '12288'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '18432'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '24576'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '30720'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '36864'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '43008'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '49152'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '55296'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '932739072'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '458041344'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '1844901888'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '1859346432'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '1095186432'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '1580544000'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '151492608'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '1349240832'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '983500800'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '1926273024'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '0'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '6144'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '12288'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '18432'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '24576'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '30720'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '36864'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '43008'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '49152'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '55296'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '964294656'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '1172281344'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '1185042432'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '356130816'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '1293926400'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '143013888'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '670248960'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '1592715264'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '1732159488'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '695654400'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '0'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '6144'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '12288'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '18432'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '24576'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '30720'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '36864'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '43008'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '49152'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '55296'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '836493312'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '1341640704'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '771151872'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '474249216'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '413509632'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '36489216'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '1615355904'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '1087248384'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '1387696128'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '759816192'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '0'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '6144'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '12288'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '18432'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '24576'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '30720'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '36864'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '43008'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '49152'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '55296'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '291323904'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '596342784'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '129724416'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '1396082688'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '746121216'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '984471552'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '1236578304'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '1247391744'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '677720064'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '1410170880'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '0'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '6144'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '12288'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '18432'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '24576'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '30720'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '36864'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '43008'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '49152'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '55296'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '814977024'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '763256832'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '1082554368'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '350613504'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '141195264'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '599924736'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '830306304'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '406370304'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '628617216'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '695734272'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '0'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '6144'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '12288'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '18432'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '24576'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '30720'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '36864'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '43008'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '49152'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '55296'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '382267392'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '282740736'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '902731776'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '42264576'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '556965888'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '48353280'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '885719040'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '146442240'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '655675392'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '703764480'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '0'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '6144'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '12288'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '18432'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '24576'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '30720'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '36864'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '43008'
Error 'OS error - {Device Busy} The device is currently busy' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '49152'
Error 'Internal error - Operation was cancelled (123)' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '55296'
