Post
by MartyMcNuts » Thu Jan 24, 2019 1:16 am
apw63 wrote: Wed Jan 23, 2019 12:44 pm
Hello I'm new to the forum. I'm trying to downgrade my BW-16D1HT. Ive been able to dump my firemare ver 3.03. The dump file is 2048 kb. I have tried to follow the windows instructions for HEX editing the clean firmware. When I flash the modified firmware i get write errors and the drives does not function. I can re flash the drive back to FW 3.03 no problems, drive returns to normal function. I must be doing something wrong witht the HEX editing. I'm using HxD as the editor. I have attached both my dump and modified files. Could some one take a look and see what ive done wrong.
Thank you
apw63, it's so much easier to use the EEPROM Data Mover to automatically do the hex editing for you. Anyway, here is a 3.02 made from your dump.
Let us know how you go..
For UHD enabled drives (AU/NZ/SG + Others) & DIY Single Drive Flasher (WW):
https://uhdenableddrives.com
apw63
Post
by apw63 » Thu Jan 24, 2019 1:37 am
Thank you very much Marty! I will let you guys know how it goes
Post
by Billycar11 » Thu Jan 24, 2019 10:17 am
the day has come we no longer need to edit firmware for people who get lost in the instructions i made an amazing 4k how to video on how to do all things the simplest way possible
here is the video:
https://www.youtube.com/watch?v=eXgybNfHhcg
if you want you can put video in op
apw63
Post
by apw63 » Fri Jan 25, 2019 2:59 am
FW that Marty made for me is working great, so far I’ve ripped 2 UHD disks. That you again, helpful good people here on this forum. Thank you Billy for making the video how to.
Andrasha
Post
by Andrasha » Sun Jan 27, 2019 8:48 pm
Is it normal to have the wrong Serial Number and Firmware Date displayed in MakeMKV after firmware downgrade?
LG WH16NS40 - Firmware downgraded to v1.02 from v1.03
Picture of Drive Information
https://imgur.com/a/ucbtWKf
Post
by Billycar11 » Mon Jan 28, 2019 12:16 am
Andrasha wrote: Sun Jan 27, 2019 8:48 pm
Yes the date was always wrong LG is dumb lol and the internal sn is different than the one on the case
jsuaggie
Post
by jsuaggie » Mon Jan 28, 2019 4:58 am
Did anyone figure out how to downgrade drive firmware using a Mac?
Post
by MartyMcNuts » Mon Jan 28, 2019 11:34 pm
jsuaggie wrote: Mon Jan 28, 2019 4:58 am
Unless you can switch your mac from SATA to IDE mode in BIOS, connect your drive via SATA and run a windows 7 or 10 live thumb drive, I doubt it can be done.
motosen34
Post
by motosen34 » Tue Jan 29, 2019 10:29 am
Is here anyone in Europe that could do the firmware downgrading? I live in Finland and don't have a motherboard that supports IDE...
Light955
Post
by Light955 » Thu Jan 31, 2019 4:53 pm
Hi everyone, Is this procedure needed if I only want to rip some 1080p blurays with the bh16ns55? I don't know which firmware it has, I should still buy one. I tried looking for the answer in other threads but I did not get it.
Post
by Billycar11 » Thu Jan 31, 2019 8:54 pm
Light955 wrote: Thu Jan 31, 2019 4:53 pm
Any firmware will work for Regular Blu rays
Malkana
Post
by Malkana » Sat Feb 02, 2019 6:32 am
Billycar11 wrote: Fri Jan 18, 2019 8:05 pm
CyberGoth wrote: Fri Jan 18, 2019 6:33 pm
Help / Advice needed.
I've just got an ASUS BW-16D1HT with firmware 3.03
Is there a way to downgrade the Firmware via USB or on a Mac?
No needs a sata connection and ide mode
Will eSata work?
Post
by Billycar11 » Sat Feb 02, 2019 6:44 am
Malkana wrote: Sat Feb 02, 2019 6:32 am
Will eSata work?
sure long as it goes the motherboard sata controller
dadregga
Post
by dadregga » Mon Feb 04, 2019 7:47 pm
Wrazor wrote: Sun Dec 16, 2018 9:53 pm
Thanks again MartyMcNuts!
My motherboard died last Thursday... talk about bad timing. >.<
New parts installed yesterday but that no longer had an IDE option.
Luckily my old server does have an IDE mode!
Used the windows 7 usb again and this time erase/write flash with DOSFLASH.
First time it failed though, wrong firmware error 02 if I remember correctly.
Did the erase/write flash a second time and it finished without error and reported writing successful!
Ripped my first 4K disc (Justice League) today!
Just want to say I successfully used the instructions in the OP to downgrade a 1.03 WH14NS40 with service code 50 to 1.02, works great, but I did have to do a 2nd ERASE/WRITE cycle with DOSFLASH before it flashed without errors, as described in the quoted post. Might make for a good FAQ/TROUBLESHOOTING section.
Many thanks to everyone who figured this out!
cmerrell75
Post
by cmerrell75 » Mon Feb 04, 2019 8:21 pm
Thanks Teddy and everyone else for all the info collected and compiled here. Last week I got an Asus BW-16D1HT manufactured mid 2018 with 3.03 on it and I was able to downgrade to 3.02. I have since successfully ripped both 1080p and 4k since the downgrade. It was fairly easy once I read through the instructions a few times. I did open up my computer and unplug the SSD before switching to IDE mode just to be safe but once I was done I plugged the drive back in, switched back to AHCI, and it booted up like nothing happened. The "Julia" version of windows was a little weird but it seemed to work fine for me.
Thanks again!
