According to VLC, Titles 26 and 33 are the correct ones, but they don't show up in the list after MakeMKV analyzes the disc. It says they are added in the log, but they aren't there in the GUI. See log snippet below and attached full log:
DEBUG: Code 10551300 at :T+l~>-iZdnuPAfG:213142496
DEBUG: Code 0 at :T+l~>-iZdnuPAfG:121274998
DEBUG: Code 0 at eQwPsO;(DY_`yW$=8a:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 18-18 were removed from title end
Title #26 was added (16 cell(s), 1:32:13)
Does this mean it's just not going to work?
Thanks for any help.
Problems with The Witch DVD
- MakeMKV_log.txt
- The Witch DVD log file
- (16.83 KiB) Downloaded 581 times
Re: Problems with The Witch DVD
A manual mode extract of title 26 worked.
