Die Hard 4K UHD and I Am Legend 4K UHD UK versions failed to decrypt. I sent the dump file to svq@makemkv.com.
Die Hard and I Am Legend UK UHD failed to decrypt
d2themc
d2themc
Re: Die Hard and I Am Legend UK UHD failed to decrypt
So how long does it normally take for the hashed keys to be updated? I'm able to decrypt Blurays no problem at all, these are the first UHDs I'm trying and I want to make sure they're not a 'bad dump'. I've got a UHD friendly drive on the correct firmware. Asus BW-16D1HT on 3.01
handcraftedbits
You submitted a dump to svq@makemkv.com, right? In my experience it takes a couple days, but never longer than a week.
d2themc
Sent January 27th and February 01st.
I noticed keys haven't been updated since 18th January though.
Using version 1.14.x, you should see a note in the log window about downloading the latest SGF when you open the first disk of a session (assuming you have not disabled contacting the web sever). This is where current versions pull the "latest keys".
d2themc
I'm an idiot.
I didn't realise it pulled the keys automagically. I've been sat here waiting for the timestamp on the hashed keys link to change.
Just ripped I am Legend, great. I'll be buying a licence.
