If you were playing them "properly", then yes. I'm ripping discs on my Lenovo ThinkPad X220 (SandyBridge Core i5-2540M CPU) right now, so I can verify that you don't need a Kaby Lake CPU for this.unknownLake wrote: ↑Sat Feb 02, 2019 7:14 pmI apologize for my ignorance but will computers with CPUs earlier than Kabylake be able to rip UHD discs with MakeMKV?
- Thanks
The LG site says the WH16NS60 system requirements are Intel 7th Gen. Kabylake Core i3 or higher.
https://www.lg.com/us/burners-drives/lg-WH16NS60
Heads up - Support for LG UHD drives
Re: Heads up - Support for LG UHD drives
what i would try first is to get the dump makemkv apparently makes idk what you will do with it but maybe since its usb only lg never thought they would need that same flash protection they have in the 1.01 1.03 and 3.03 fwsjonghotti wrote: ↑Fri Feb 01, 2019 2:40 pmHad a stack of 8 slims to go through today, 1 BU50N firmware BW50, 5 BU40Ns firmware 1.02, 1 BU40N firmware 1.01, 1 BU40N firmware 1.00. So both 1.00 and 1.01 are friendly and released in 2016 and 2017 respectively with 1.02 the cock-blocker appearing in 2018.
We got any electrical engineers around here? I need some help figuring out where and which pins to solder a SATA data connector onto on an LG BP60NB10 which is USB out only in order to dump it's firmware. Happy to send you one if schematics are not to be found online.
so just delete all your dump_SD_xxxxx.tgzs open makemkv with only that drive connected and i guess just wait idk what triggers makemkv to make the dump maybe mike will tell us or yell at us.mike admin wrote: ↑Wed Jan 30, 2019 6:55 amI want your firmware!!!!
Please navigate to MakeMKV data directory (location can be looked up in preferences). Inside you will find one or more files named dump_SD_xxxxx.tgz . Please send them all to support@makemkv.com . Thanks!
Now that right there is a "crackin'" idea. I will actually get right on that. Cheers Billy.Billycar11 wrote: ↑Sun Feb 03, 2019 8:53 amwhat i would try first is to get the dump makemkv apparently makes idk what you will do with it but maybe since its usb only lg never thought they would need that same flash protection they have in the 1.01 1.03 and 3.03 fwsso just delete all your dump_SD_xxxxx.tgzs open makemkv with only that drive connected and i guess just wait idk what triggers makemkv to make the dump maybe mike will tell us or yell at us.mike admin wrote: ↑Wed Jan 30, 2019 6:55 amI want your firmware!!!!
Please navigate to MakeMKV data directory (location can be looked up in preferences). Inside you will find one or more files named dump_SD_xxxxx.tgz . Please send them all to support@makemkv.com . Thanks!![]()
Hi All
I need a little help in understanding this thread.
After reading this and other threads I have ordered a LG WH14NS40 originally and after reading more I see a lot about this drive an LG WH16NS60 as being UHD capable and either is or will be supported.
OK, I realize the first drive need a firmware downgrade but this thread seems to imply that the WH16NS60 will work without a mod, is that True?
So far I like the WH16NS60 since it doesn't have the sleep bug and has UHD disc support out of the box.
Does makemkv work now or sometime latter? If latter anyone have timeline.
Rew
Rew
Mike has stated that it will be supported soon. It is on firmware 1.00 already but he said support for 1.01 is coming. No time frame given as to when that will happen.
OK, Thanks just was not sure with the way the thread read.
Rew
Rew
Polar Hacker
Hi there! I'm interested in converting HD and UHD Blu-ray discs, but I am torn as to which drive to get. This post recommends to buy a native UHD Drive, not a friendly one. Is there much of a difference besides the sleep bug? Also, it doesn't work on the latest firmware. Is it possible to downgrade, and when will it support the latest firmwares? Lastly, I'm on a bit of a budget, so if someone could recommend a relatively affordable drive I'd be most appreciative. Thanks!
- Contact:
This is what we were working on for a while - viewforum.php?f=19 . If you have any issues with LibreDrive mode, please discuss it in appropriate sub-forum. Thanks!
Just for my education can someone explain to me what is the "sleep bug"? It is continually mentioned in various posts, but when I search the forums I cannot find a description. I currently rip UHD discs usually an ASUS friendly drive. Am I just not recognizing this bug? Thanks!
The "sleep bug" is where the drive stops responding because it has gone into a sleep mode, usually because you stopped sending commands to it while selecting what to rip.
When you put a uhd disk in a non native uhd drive after 2 mins of inactivity the drive will go to sleep and not wake up with a uhd disk inside and make a horrible seeking noise it is easily fixed by ejecting the disk and then closing the driveXrayDoc88 wrote: ↑Wed Feb 06, 2019 5:21 pmJust for my education can someone explain to me what is the "sleep bug"? It is continually mentioned in various posts, but when I search the forums I cannot find a description. I currently rip UHD discs usually an ASUS friendly drive. Am I just not recognizing this bug? Thanks!
A minor annoyance at best and certainly not a reason to pick one drive over another. Two minutes is a long time when you're just clicking check boxes come on.
What's that? Oh yeah, Julia agrees with me, total non issue!
Hey all, having an issue and I haven't found an answer after trying for the past week. I have the following drive -
OS device name: F:
Manufacturer: hp HLDS
Product: BDRE BU50N
Revision: BW50
Serial number: KDDG96G1422
Firmware date: 2116-08-10 10:14
Bus encryption flags: 1F
Highest AACS version: 61
Any UHD disc I attempt to rip fails. For example:
Disc Information
Label: WATCHMEN
Timestamp: 2016-05-27 10:57:51
Data capacity: 85.9 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Returns the following error:
MakeMKV v1.14.2 win(x64-release) started
Saved SD dump file as C:\Users\dflee/.MakeMKV/UHD/dump_SD_05A611E4F940A89B7924.tgz
Please send the file "C:\Users\dflee/.MakeMKV/UHD/dump_SD_05A611E4F940A89B7924.tgz" to support@makemkv.com
Downloading latest SDF to C:\Users\dflee/.MakeMKV/UHD ...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
<insert a bunch more lines of this>
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Downloading latest HK to C:\Users\dflee/.MakeMKV/UHD ...
Saved AACS dump file as C:\Users\dflee/.MakeMKV/UHD/MKB20_v61_Watchmen-_Ultimate_Cut_EE7F.tgz
I am unclear what is going wrong here. The error states the host cert is revoked, but I'm not sure how that could have happened. I bought this drive in December once I heard official support was coming and it hasn't been used for anything else.
Is the firmware unsupported? Do I need to wait for a new version of MakeMKV with a higher rev cert as some threads imply? I have placed keys_hashed.txt in the defined data directory for MakeMKV and it is putting dumps in the same directory so I assume its in the right place. I have about 10 UHD's, all do the same even ones with older AACS versions like Mad Max.
Thanks for any assistance, it is appreciated.
OS device name: F:
Product: BDRE BU50N
Revision: BW50
Disc Information
Label: WATCHMEN
Number of layers: 3
Yes it needs to be flashed with BU40N 1.00 which I am happy to send you. Alternatively I'll swap you a BU50N with supported firmware for yours.
