Heads up - Support for LG UHD drives
jonghotti
Re: Heads up - Support for LG UHD drives
Post by jonghotti »
MartyMcNuts wrote: Fri Feb 01, 2019 11:03 pm
jonghotti wrote: Fri Feb 01, 2019 2:40 pm Had a stack of 8 slims to go through today, 1 BU50N firmware BW50, 5 BU40Ns firmware 1.02, 1 BU40N firmware 1.01, 1 BU40N firmware 1.00. So both 1.00 and 1.01 are friendly and released in 2016 and 2017 respectively with 1.02 the cock-blocker appearing in 2018.
We got any electrical engineers around here? I need some help figuring out where and which pins to solder a SATA data connector onto on an LG BP60NB10 which is USB out only in order to dump it's firmware. Happy to send you one if schematics are not to be found online.
Do you have an esata adapter on your computer? You could possibly get a usb to esata cable so that your usb drive would connect to the esata port, then the esata port is connected to your sata motherboard connection.
Something like
https://www.startech.com/au/HDD/Adapter ... B3S2ESATA3
and
https://www.amazon.ca/StarTech-com-ESAT ... B000NPKGH4
Good call Mr. Nuts I do have esata ports on a couple of these machines I like these older HP SFF desktops. Supposed to be connected to SATA 0 however so why not just a regular SATA > mini usb? I still have a feeling I'm going to end up soldering something but we'll get it done!!
jonghotti wrote: Sat Feb 02, 2019 6:31 am
Something like
and
Yeah, well I thought it might be worth a try. Really what's the worst that can happen? It doesn't work...
Post by mike admin »
Let me repeat - all drives with newer firmwares (including slim USB-only) WILL be supported soon.
Post by SamuriHL »
Awesome! Truly amazing that you're able to support all drives.
Sent from my Pixel XL using Tapatalk
tuuatwaffle
Post by tuuatwaffle »
mike admin wrote: Sat Feb 02, 2019 11:44 am Let me repeat - all drives with newer firmwares (including slim USB-only) WILL be supported soon.
Is that including Pioneer? Thanks for the fantastic work you do.
spl147
Post by spl147 »
Pioneer might be supported, how many times must it be said
Sent from my iPhone Xs Max using Tapatalk Pro
tuuatwaffle
spl147 wrote: Sat Feb 02, 2019 4:57 pm
Probably a few more if Mike says All drives will be supported.
spl147 wrote: Sat Feb 02, 2019 4:57 pm Pioneer will never be supported, how many times must it be said
I have to take it back. Pioneer might be supported after all. I cannot provide any hints or estimates, but it is sufficient to say that "never" part should be certainly stroked out.
spl147
Post by spl147 »
I stand corrected
Xavier24
Post by Xavier24 »
Thanks again Mike for this good news.
I will be able to enjoy with my LG BU40N usb player full of MakeMkv.
I am impatient ... :D
tuuatwaffle
mike admin wrote: Sat Feb 02, 2019 5:18 pm
Hopefully. Cracking work sir.
unknownLake
Post by unknownLake »
I apologize for my ignorance but will computers with CPUs earlier than Kabylake be able to rip UHD discs with MakeMKV?
- Thanks
The LG site says the WH16NS60 system requirements are Intel 7th Gen. Kabylake Core i3 or higher.
https://www.lg.com/us/burners-drives/lg-WH16NS60
jonghotti
Post by jonghotti »
ziggy101 wrote: Sat Feb 02, 2019 4:18 am
jonghotti wrote: Fri Feb 01, 2019 2:40 pm We got any electrical engineers around here? I need some help figuring out where and which pins to solder a SATA data connector onto on an LG BP60NB10 which is USB out only in order to dump it's firmware. Happy to send you one if schematics are not to be found online.
The few USB drives I've taken apart had an internal SATA interface, but a small pc board was connected to it to translate to a USB connection. So it looks like you can easily unplug that board and gain access to a regular SATA connector once you get the thing out of the case (I haven't actually tried it, but it sure looks like it would work).
You are correct, most of them do function like that. Except for this one, it's one single piece. Certainly more cost effective to wire the connector directly to the ICs that are running the device. I was going to try that SATA > USB cable idea something tells me it's not going to be that easy because if it were someone would have already done it :)
jonghotti
Post by jonghotti »
Xavier24 wrote: Sat Feb 02, 2019 5:47 pm Thanks again Mike for this good news.
Why can't you enjoy it now?
jonghotti
Post by jonghotti »
unknownLake wrote: Sat Feb 02, 2019 7:14 pm I apologize for my ignorance but will computers with CPUs earlier than Kabylake be able to rip UHD discs with MakeMKV?
- Thanks
Yes please ignore those specs those are for using the drive as a playback device in a computer which is something I've still never seen anyone do. Pretty much any drive in any computer can be used with makemkv. Requirements are basically that your computer has a pulse and a large hard drive :)
