Heads up - Support for LG UHD drives
manHands
Re: Heads up - Support for LG UHD drives
#121 Post by manHands » Fri Feb 01, 2019 12:33 am
jonghotti wrote: Fri Feb 01, 2019 12:19 amIf you're not doing it yourself I'd be happy to do it for you for the low low price of 0 dollars and 0 cents. Feel free to email me.
I have a WH16NS60 with 1.01 firmware I need downgraded to 1.00 to be able to rip UHD discs, and I'm too impatient to wait. What's your email? Sorry I'd send you a PM, but doesn't look I have the proper rights yet. I'm just a lurker and seldomly post. :)
demon
#122 Post by demon » Fri Feb 01, 2019 12:42 am
jonghotti wrote: Fri Feb 01, 2019 12:19 am Thank you I've been looking high and low for the NS60 1.02 but it just doesn't exist :)
Yes you need a flashing. If you're not doing it yourself I'd be happy to do it for you for the low low price of 0 dollars and 0 cents. Feel free to email me.
If you have a WH16NS60 1.00 ROM image and a tool to reflash the drive with it, I'd appreciate it. I'm not afraid to do it myself, I just haven't found anywhere that has the thing.
#123 Post by SamuriHL » Fri Feb 01, 2019 12:47 am
I just did exactly that. I extracted my firmware from the drive, used the nifty data mover tool with the NS60 1.0 clean firmware that's floating around (https://www106.zippyshare.com/v/x0llCZ1c/file.html gotten from https://club.myce.com/t/dosflash-v2-0-p ... ves/399911) and then I just flashed it. I now have that magical DEBUG: Code 03DF/03 status.
#124 Post by Billycar11 » Fri Feb 01, 2019 4:51 am
demon wrote: Fri Feb 01, 2019 12:42 am
i have a video doing it to a wh16ns60 from 1.01 to 1.00 here : https://www.youtube.com/watch?v=eXgybNfHhcg
Xavier24
#125 Post by Xavier24 » Fri Feb 01, 2019 8:46 am
Hello everyone,
as I say above, I have a LG BU40N V1.02 drive that unfortunately displays the default 01be / 03.
Do you know if Mike will also correct this problem, or should I move towards a firmware type 1.01 in place of the one I have?
I admit I'm not a geek and I'm afraid to flash my reader and make things.
So do I have to wait for Mike's magic or get started on a new firmware version?
Thanks to All
jonghotti
#126 Post by jonghotti » Fri Feb 01, 2019 1:42 pm
Xavier24 wrote: Fri Feb 01, 2019 8:46 am Hello everyone,
Thanks to All
I would encourage you to have your drive flashed by one of us geeks, although I prefer the term nerd, or dude, or simply Alex :-)
alexcoluzzi32@gmail.com
jonghotti
#127 Post by jonghotti » Fri Feb 01, 2019 2:40 pm
Had a stack of 8 slims to go through today, 1 BU50N firmware BW50, 5 BU40Ns firmware 1.02, 1 BU40N firmware 1.01, 1 BU40N firmware 1.00. So both 1.00 and 1.01 are friendly and released in 2016 and 2017 respectively with 1.02 the cock-blocker appearing in 2018.
We got any electrical engineers around here? I need some help figuring out where and which pins to solder a SATA data connector onto on an LG BP60NB10 which is USB out only in order to dump it's firmware. Happy to send you one if schematics are not to be found online.
#128 Post by MartyMcNuts » Fri Feb 01, 2019 11:03 pm
jonghotti wrote: Fri Feb 01, 2019 2:40 pm Had a stack of 8 slims to go through today, 1 BU50N firmware BW50, 5 BU40Ns firmware 1.02, 1 BU40N firmware 1.01, 1 BU40N firmware 1.00. So both 1.00 and 1.01 are friendly and released in 2016 and 2017 respectively with 1.02 the cock-blocker appearing in 2018.
Do you have an esata adapter on your computer? You could possibly get a usb to esata cable so that your usb drive would connect to the esata port, then the esata port is connected to your sata motherboard connection.
Something like
https://www.startech.com/au/HDD/Adapter ... B3S2ESATA3
and
https://www.amazon.ca/StarTech-com-ESAT ... B000NPKGH4
demon
#129 Post by demon » Fri Feb 01, 2019 11:26 pm
Billycar11 wrote: Fri Feb 01, 2019 4:51 am i have a video doing it to a wh16ns60 from 1.01 to 1.00 here : https://www.youtube.com/watch?v=eXgybNfHhcg
Thanks for this. It filled in some gaps in my understanding. I was able to use my backup NAS over IPMI with a 7 PE disc and do the necessary downgrade, and I'm now ripping a disc with the drive transplanted back into my workstation.
ziggy101
#130 Post by ziggy101 » Sat Feb 02, 2019 4:18 am
jonghotti wrote: Fri Feb 01, 2019 2:40 pm We got any electrical engineers around here? I need some help figuring out where and which pins to solder a SATA data connector onto on an LG BP60NB10 which is USB out only in order to dump it's firmware. Happy to send you one if schematics are not to be found online.
The few USB drives I've taken apart had an internal SATA interface, but a small pc board was connected to it to translate to a USB connection. So it looks like you can easily unplug that board and gain access to a regular SATA connector once you get the thing out of the case (I haven't actually tried it, but it sure looks like it would work).
jonghotti
#131 Post by jonghotti » Sat Feb 02, 2019 6:31 am
MartyMcNuts wrote: Fri Feb 01, 2019 11:03 pm
Something like
and
Good call Mr. Nuts I do have esata ports on a couple of these machines I like these older HP SFF desktops. Supposed to be connected to SATA 0 however so why not just a regular SATA > mini usb? I still have a feeling I'm going to end up soldering something but we'll get it done!!
#132 Post by MartyMcNuts » Sat Feb 02, 2019 10:03 am
jonghotti wrote: Sat Feb 02, 2019 6:31 am
Something like
and
Yeah, well I thought it might be worth a try. Really what's the worst that can happen? It doesn't work...
#133 Post by mike admin » Sat Feb 02, 2019 11:44 am
Let me repeat - all drives with newer firmwares (including slim USB-only) WILL be supported soon.
#134 Post by SamuriHL » Sat Feb 02, 2019 12:54 pm
Awesome! Truly amazing that you're able to support all drives.
Sent from my Pixel XL using Tapatalk
tuuatwaffle
#135 Post by tuuatwaffle » Sat Feb 02, 2019 3:37 pm
mike admin wrote: Sat Feb 02, 2019 11:44 am Let me repeat - all drives with newer firmwares (including slim USB-only) WILL be supported soon.
Is that including Pioneer? Thanks for the fantastic work you do.
