I was able to extract the data from the disc by painstakingly reading 100 MB chunks of the disc in dd, ejecting and reinserting the disc when I/O errors occurred, then joining the chunks together to an ISO using cat.
I can perfectly browse the ISO in Finder, but when I try to open it in MakeMKV, it complains that the volume key is missing and can't decrypt it.
MakeMKV v1.12.0 darwin(x64-release) started
The program can't find any usable optical drives.
Saved AACS dump file as [...]/Library/MakeMKV/MKB20_v61_X-Men_Apocalypse_BE17.tgz
