Sorry to double-post, but this was opened by someone else in the DVD forum. I thought it should be here as I am using the BD version of the film. I am experiencing an issue where this movie stops at about 10-15% and says "Complete". The output file is the first 3.35GB of the movie. The movie and audio files on the BD are around 12GB.
The disc looks like it was produced by Shout! Factory, LLC. They are releasing all of the Roger Corman movies in a series called "Roger Corman Classics".
Debug log started at Mon Aug 09 02:41:16 2010 , written by MakeMKV v1.5.8 win(x86-release)
Using 519168KB for read cache.
001005:0000 MakeMKV v1.5.8 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Gary/MakeMKV_log.txt
DISCID=2456AA3D38F9A737E6C149ACDD678C0657CDE2E1
003307:0000 File 00003.mpls was added as title #0
003025:0000 Title #00016.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 01003.mpls is equal to title 00003.mpls and was skipped
003025:0000 Title #01016.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00004.m2ts was added as title #1
003307:0000 File 00005.m2ts was added as title #2
003307:0000 File 00006.m2ts was added as title #3
003307:0000 File 00007.m2ts was added as title #4
003307:0000 File 00008.m2ts was added as title #5
003307:0000 File 00009.m2ts was added as title #6
003307:0000 File 00010.m2ts was added as title #7
003307:0000 File 00011.m2ts was added as title #8
003025:0000 Title #00012.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00013.m2ts was added as title #9
003025:0000 Title #00014.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00021.m2ts was added as title #10
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory D:/dvd//Death_Race_2000
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Death Race 2000 BD fails at 10%
- Contact:
Re: Death Race 2000 BD fails at 10%
When you select the main movie, what size and duration is shown on a right pane?
- Contact:
Please send CLPI/MPLS files per instructions at http://www.makemkv.com/faq/item/8/catid/6
PM sent to Mike.
Requested files have been emailed.
Re: Death Race 2000 BD fails at 10% *SOLVED*
1.6.0 fixed the problem. Rip success!
