Heads up - Support for LG UHD drives
Ph886
Re: Heads up - Support for LG UHD drives
Post by Ph886 »
mattyj2001 wrote:
demon wrote: Wed Jan 30, 2019 2:43 am What OS are you on? For me, on Linux, this is what MakeMKV looked like after ripping a disc on my laptop:
https://owncloud.now.ai/index.php/s/UPb1hifvpgog22d
The "DEBUG: Code 03DF/..." line is what you should see if it's successfully able to rip from your drive. My BU40N worked fine with the 1.01 firmware (note the "Revision:" line in the box on the right; that's how the 1.01 firmware on this drive identifies itself).
And no, you don't need to redownload the app. The "Downloading latest SDF" and "Downloading latest HK" items in the log window are the app downloading the data it needs to do the rip. If you see "DEBUG: Code 01BE/...", as mike said, then your drive isn't cooperating. It looks like 1.00 is the latest firmware for that drive on the HLDS site, so it may just not work for a bit yet, but I'm sure mike is working on it.
I have a BU40N that is _not_ working with firmware 1.01, but it seems to be some other weird kind of firmware, maybe? The Drive Information box in MakeMKV reports this (on a Mac):
OS device name: /dev/rdisk2
Product: BD-RE BU40N
Revision: 1.01
Serial number: KZPHCCG2136
Firmware date: 2117-12-22 12:21
Bus encryption flags: 1F
Highest AACS version: 66
But in the log window it reports:
"Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.01d" opened in OS access mode."
Firmware 1.01d? Whatever that is ... Also, confirmed I have the latest keys_hashed.txt in my data directory and I am attempting to rip a disk that is known to work (2001. I feel like we're all the same kind of sci-fi nerds.)
Not sure if it's possible/practical to downgrade/sidegrade the firmware.
We haven’t needed the txt file in some time now. It’s possible to downgrade/flash just like the other drives , but without knowing what’s not working it’s impossible for us to give any advice. Did you attempt to rip and get to the selection screen? Were errors present when attempting the rip?
akjeff
Post by akjeff »
I have the WH16NS40 with patched 1.02 firmware. It was decrypting 4K disks prior to all of this and I am getting the DEBUG: Code 03DF message but I have noticed that decrypting ANYTHING (including DVD's), the process seems more sensitive. I seem to be getting more crashes in MakeMKV that I wasn't getting before.
vexorg
Post by vexorg »
Hello all, I'm able to backup UHD discs with my setup. I thought I would share my configuration and details in case it's helpful to anyone.
I have a BU50N that I purchased from Amazon.com around December 30th 2018. Firmware version appears to be "BW50" (sometimes appears as "BW50d" in places). The firmware date is "2116-12-22 10:52". It's connected via USB enclosure (a Vantec slim USB3 enclosure) purchased on amazon.com at the same time, to a mac running macOS 10.14.3 and MakeMKV 1.14.2. Everything is working great and I'm getting 6X speeds out of the drive!
mattyj2001
Post by mattyj2001 »
Ph886 wrote: Wed Jan 30, 2019 3:04 pm
Revision: 1.01
It never gets to the selection screen, it goes through the decryption part then goes back to the main screen. The start of the debug log window goes like this:
MakeMKV v1.14.2 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/mattyj/MakeMKV_log.txt
Downloading latest SDF to /Users/mattyj/Library/MakeMKV ...
DEBUG: Code 01BE/03
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:IOBDServices:143257fceb19b800:HL-DT-ST BD-RE BU40N 1.01'
DEBUG: Code 0 at C-m9rhoWt,$NB;6=#:213130766
DEBUG: Code 0 at RPGj*V3qs7&kNo3AvP:121263521
Then those last three lines repeat in some form or another about 100 times, then it ends on:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:143257fceb19b800:HL-DT-ST BD-RE BU40N 1.01'
DEBUG: Code 0 at RPGj*V3qs7&kNo3AvP:213132721
DEBUG: Code 4 at RPGj*V3qs7&kNo3AvP:213130904
Saved AACS dump file as /Users/mattyj/Library/MakeMKV/MKB20_v66_2001-_A_Space_Odyssey_C6EE.tgz
DEBUG: Code 0 at 3-&G:T%sH~_VhW_a:29396115
DEBUG: Code 0 at 3-&G:T%sH~_VhW_a:213134262
Poking around the forum here, this kind of points to the AACS version the drive recognizes vs what MakeMKV is capable of ...? Or something along those lines.
The 2001 disk claims AACS2.0/C v66. The drive claims "Highest AACS version: 66". But since others have said they ripped the 2001 UHD, seems like there shouldn't be a mismatch? Unless I did something earlier and inadvertently to blacklist AACS v66 on this drive (like try to rip a disk before this drive was supported ...?)
mattyj2001 wrote: Thu Jan 31, 2019 5:29 am
you need to downgrade to bu40n 1.00 i have it if you need it and follow teddy's guide: https://www.makemkv.com/forum/viewtopic ... 16&t=17058 or my video guide: https://www.youtube.com/watch?v=eXgybNfHhcg
mattyj2001
Billycar11 wrote: Thu Jan 31, 2019 6:42 am
Cool, thanks. I'll have to go another route, though, unfortunately. My household is 100% Mac, I have no friends, and I work for a company that is in the 'content creator pipeline' in a big way, so probably frowned upon to do that at work. :)
jonghotti
Post by jonghotti »
I’ll give it a shot, PM sent.
Ask me for a 4K “UHD Friendly” Blu Ray drive to try before you buy!
Post by mike admin »
akjeff wrote: Wed Jan 30, 2019 7:46 pm I have the WH16NS40 with patched 1.02 firmware. It was decrypting 4K disks prior to all of this and I am getting the DEBUG: Code 03DF message but I have noticed that decrypting ANYTHING (including DVD's), the process seems more sensitive. I seem to be getting more crashes in MakeMKV that I wasn't getting before.
If you are getting a proper crash (as in crashed program) please submit the dump with http://www.makemkv.com/onlinehelp/dump.html . I f by crash you mean a lot of errors, please do submit the log file to support@makemkv.com . Thanks!
Ph886
Post by Ph886 »
Revision: 1.01
DEBUG: Code 01BE/03
As Billy said the error code points to firmware version not supported (the error code 01BE was in mike’s announcement post).
Post by SamuriHL »
SamuriHL wrote: Tue Jan 29, 2019 11:42 pm My NS60 came with 1.02. I just bought it in December. I've not yet tried it as I was waiting for the support. I'll try tomorrow but it's definitely not flashed.
Ok so I can't read. It came with 1.01. I don't know why I thought it said 1.02. I'm about to install it and see what happens. Based on previous responses I'm guessing it's not going to work yet. Sorry for the confusion. MFG date is 10/2018.
EDIT: As expected DEBUG: Code 01BE/03
Post by SamuriHL »
Is there any real reason not to downgrade the NS60 drive to 1.00 firmware? The only change between 1.00 and 1.01 is the removal of the "friendly" aspect of the drive, correct? I already created the firmware, I just haven't flashed it yet.
jonghotti
Post by jonghotti »
SamuriHL wrote: Thu Jan 31, 2019 11:48 pm Is there any real reason not to downgrade the NS60 drive to 1.00 firmware? The only change between 1.00 and 1.01 is the removal of the "friendly" aspect of the drive, correct? I already created the firmware, I just haven't flashed it yet.
No reason I know of.
You can always cross flash it to ASUS 3.01 for the speed boost as well :-)
the only info they gave for the 1.01 update was improved disk compatibility and thats the same thing they said for 1.03 and 3.03 update that killed uhd friendlynes i would say there is no reason not to.
i would not go to the asus firmware it has the sleep bug and thats annoying
jonghotti
Post by jonghotti »
The "sleep bug" doesn't bother me, waiting any longer than I have to for a rip to finish does though.
Post by SamuriHL »
Yea sorry about that. Brain malfunction. I could have sworn when I pulled it out of the box and read the label it said 1.2 but um no. As for ASUS I already have an ASUS with 3.02 on it and I use that regularly to rip. I decided to grab the NS60 when this thread came around just to have one on hand. Yea, I think I'm going to go flash it. Like I said, I already have the firmware created to flash it, but, I appreciate the offer. I've got both the ASUS and LG installed in the same machine now. :D
