ASUS BW-16D1HT 3.02 and problem reading DVDs
thetoad
Post by thetoad »
I recently replaced my old bluray drive with this asus drive I had sitting in my closet (cheap rebate purchase a long time ago before anyone was thinking UHD ripping).
However, it is very inconsistent as a dvd ripper (haven't even tried blurays yet). It seems to get itself "stuck" in that it will repeatedly have some sort of sense error but can retry and then read. after enough of doing this, it sometimes gets "unstuck" and then can continue to read fine without retries for an extended period of time.
any clue what's going on? I know this isn't a UHD issue (or even makemkv specific), but its really annoying me for making full disc DVD rips.
Re: ASUS BW-16D1HT 3.02 and problem reading DVDs
If you're getting sense errors, that's hardware.
Are you running in DEBUG LOGGING mode? What kind of errors are you getting?
jonghotti
Post by jonghotti »
ASUS drives aren't reading anything for me. Here's some debug codes.
MakeMKV v1.14.2 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/alexcoluzzi/MakeMKV_log.txt
Optical drive "BD-RE ASUS BW-16D1HT 3.01d" opened in OS access mode.
Backing up disc into folder "/Volumes/My Passport/backup/BATTLESHIP"
Downloading latest SDF to /Users/alexcoluzzi/Library/MakeMKV ...
DEBUG: Code 03DF/03/E064BA3E3F81
Downloading latest HK to /Users/alexcoluzzi/Library/MakeMKV ...
DEBUG: Code 2 at zp3f"JV]W'"9^\X&-#\WrJ1:29393447
DEBUG: Code 0 at `o@<-i39-{I+}w; :(]:213132698
DEBUG: Code 0 at :{`'2(+F0q|?:W.dIk2\:121265154
Backup failed
Backup failed
Backup failed
thetoad
Post by thetoad »
I can't even open discs in makemkv (i can open them in dvd decrypter after many retries and sometimes it resets itself and starts working without any retries)
Debug logging enabled, log will be saved as C:\Users\spott/MakeMKV_log.txt
DEBUG: Code 100663296 at Gn,QlSs)zv!z6u9zh1:213131548
DEBUG: Code 100663296 at Gn,QlSs)zv!z6u9zh1:121261934
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading 'BD-RE ASUS BW-16D1HT 3.02' at offset '69632'
LIBMKV_TRACE: UDF mount: reading in reserve VDS extent
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading 'BD-RE ASUS BW-16D1HT 3.02' at offset '100352'
LIBMKV_TRACE: UDF mount: error reading volume space
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading 'BD-RE ASUS BW-16D1HT 3.02' at offset '530432'
DEBUG: Code 0 at A3d6B]#V9\CAJ^!oT.F:29394183
DEBUG: Code 0 at A3d6B]#V9\CAJ^!oT.F:29393930
DEBUG: Code 3221225861 at Gn,QlSs)zv!z6u9zh1:213131548
DEBUG: Code 3221225861 at Gn,QlSs)zv!z6u9zh1:121261934
Error 'OS error - The I/O device reported an I/O error' occurred while reading 'BD-RE ASUS BW-16D1HT 3.02' at offset '530432'
though apparently after my last reboot and attempt to use makemkv, nothing is working with it right now.
and after letting dvd decrypter go after it for bit is now reading fine again. so confused.
jonghotti
Post by jonghotti »
There are Windows 10 security settings that are definitely screwing with makeMKV working properly on my systems. When i find exactly which one it is I'll post it here.
thetoad
Post by thetoad »
the issue here isn't a makemkv issue, its a hardware issue. where the hardware gets into a funky state.
jonghotti
Post by jonghotti »
Interesting, I've no idea what my issue is then but I've got 3 Windows 10 Pro machines where makeMKV reports "no usable optical drive found" immediately when the program is run. Windows of course sees the drive just fine.
I'm currently limping by with a pair of Macbook Pros, high sierra on one and something else on the other. The Mac version of makeMKV is working fine thank God and until Tuesday Windows was also good but not any longer.
Post by SamuriHL »
Stupid question....have you tried running MakeMKV in admin mode? I've seen that issue in Win 10 before where the drives wouldn't show up unless MakeMKV was started as admin.
thetoad
Post by thetoad »
turns out my issue was a bad sata cable. make me wonder if I didn't need to replace it in the first place. oh well.
waldo22
Post by waldo22 »
I want to add a "me too" to this, sort of.
My BW-16D1HT with 3.02 rips BluRay and UHD just fine, but won't even recognize a DVD.
Does this indicate it's a DVD laser issue?
An older DVD drive rips the same DVDs just fine, so I've got backup plans. Just annoying.
Thoughts?
st4evr
Post by st4evr »
waldo22 wrote: Sat Jul 06, 2019 12:49 am I want to add a "me too" to this, sort of.
Thoughts?
Some here:
https://www.makemkv.com/forum/viewtopic ... ser#p74489
waldo22
Post by waldo22 »
Thanks, I missed that thread somehow.
It's funny this UHD drive basically won't read ANY DVD. My Sony BluRay drive usually reads DVDs fine, but read both of the discs I tried today with errors.
My red-laser Memorex USB-powered DVD-only drive worked perfectly.
Sounds like the long-term solution is to just use the red-laser DVD drives for DVDs.
Thanks for the tip!
thetoad
Post by thetoad »
I've ripped 10s to hundreds of DVDs with this drive. Now, its not a particularly fast DVD ripper, but it rips them without any issues/
