Every disc hangs....Using direct disc access mode DEBUG: Code 03DF
gforce40
Post by gforce40 »
All of a sudden every disc hangs @ :
"Using direct disc access mode
DEBUG: Code 03DF"
I have never had a problem before today.
NF discs, "A Simple Favor", "Venom", "The House With A Clock In It's Walls"
All hang at the same point and nothing seems to help.
Windows 10
MKV 1.14.2 (registered)
Reboot, Unplug, Disconnect....Nothing...Just hangs on every disc.
gforce40
Re: Every disc hangs....Using direct disc access mode DEBUG: Code 03DF
Post by gforce40 »
Dump e-mailed...
Was able to get all three started this morning. (Plays fine)
Took several minutes though before the mpls files started adding.
Thought it was hung again for a minute there.
MakeMKV v1.14.2 win(x64-release) started
Downloading latest SDF to C:\Users\gakee/.MakeMKV ...
DEBUG: Code 03DF
Using Java runtime from C:\Program Files (x86)\Java\jre1.8.0_181\bin\java.exe
File 00003.mpls was added as title #0...........(etc)
smartieyoung
Post by smartieyoung »
i still get the debug 03df message but now the decryption of the first man blueray disc is going fine, :?: weird how technology works sometimes.I would be happy to provide logs if mike would like them.kind regards
smartieyoung
ok i will say on my end copying blu ray discs works I still get the debug error and hangs on uhd disc backups.i have tried erasing my current version of makemkv and reinstalling the latest version from the website.still no-go,im wondering if there is anything on my end i can do to fix the problem? ideas anyone?
Post by mike admin »
smartieyoung wrote:
Mon Jan 28, 2019 4:59 pm
https://www.makemkv.com/forum/viewtopic.php?f=8&t=18833
smartieyoung
thanks mike i will read your posts,its an honor to be quoted by you,keep up doing what your doing :wink:
