BD or UHD no longer work
smartieyoung
Re: BD or UHD no longer work
thanks for the update,everything works nice on my end
jayper
Fix is working here. Thanks so much!jayper wrote: Mon Jan 28, 2019 4:12 am Manufacturer: HL-DT-ST
Product: BD-RE WH16NS40
Revision: 1.02
Firmware date: 2117-03-10 16:50
DEBUG: Code 03DF/02/62194E19F4EC
scdadd
am i suppose to be updating the firmware for my Blu-Ray Drive? if so how do i do it? whats going on here?
No usually downgrade what drive model and firmware do you have ?scdadd wrote: Fri Feb 15, 2019 7:56 am am i suppose to be updating the firmware for my Blu-Ray Drive? if so how do i do it? whats going on here?
mldardy
Hi all I get this issue when on 'A Quiet Place' UHD disc. It keeps displaying this error and then goes back to the main screen where it shows the disc is loaded and ready to be burned. I am using ASUS-BW-16D1HT. Is there a firmware install that I need to get this to work? I just got this unit yesterday.
Show us your exact error.mldardy wrote: Fri Jan 10, 2020 11:52 pm Hi all I get this issue when on 'A Quiet Place' UHD disc. It keeps displaying this error and then goes back to the main screen where it shows the disc is loaded and ready to be burned. I am using ASUS-BW-16D1HT. Is there a firmware install that I need to get this to work? I just got this unit yesterday.
And read this https://www.makemkv.com/forum/viewtopic ... 16&t=19634
mldardy
Billycar11 wrote: Sun Jan 12, 2020 8:22 amShow us your exact error.mldardy wrote: Fri Jan 10, 2020 11:52 pm Hi all I get this issue when on 'A Quiet Place' UHD disc. It keeps displaying this error and then goes back to the main screen where it shows the disc is loaded and ready to be burned. I am using ASUS-BW-16D1HT. Is there a firmware install that I need to get this to work? I just got this unit yesterday.
Clean the disk , get a replacement disk , get a new drive
mldardy
Have cleaned it, and bought the drive from one of your sellers and received it on Thursday.Billycar11 wrote: Sun Jan 12, 2020 9:01 pmClean the disk , get a replacement disk , get a new drive
None of them are "my" sellers just recommend according to area before you blame the drive and seller you should to get a replacement disk, for all the drives I sell I include a test report of UHD backup success of a dual layer and triple layer disksmldardy wrote: Sun Jan 12, 2020 10:15 pmHave cleaned it, and bought the drive from one of your sellers and received it on Thursday.Billycar11 wrote: Sun Jan 12, 2020 9:01 pmClean the disk , get a replacement disk , get a new drive
mldardy
I keep seeing multiple people with different drives getting errors when burning UHD discs in this forum so if you are testing your drives they aren't being tested thoroughly enough. This is kind of ridiculous to sell these products and discs still don't burn correctly.Billycar11 wrote: Sun Jan 12, 2020 10:19 pmNone of them are "my" sellers just recommend according to area before you blame the drive and seller you should to get a replacement disk, for all the drives I sell I include a test report of UHD backup success of a dual layer and triple layer disksmldardy wrote: Sun Jan 12, 2020 10:15 pmHave cleaned it, and bought the drive from one of your sellers and received it on Thursday.Billycar11 wrote: Sun Jan 12, 2020 9:01 pm
Did you buy it from me? If you did and are having problems email me I will replace the drive if you just got it Thursday.mldardy wrote: Sun Jan 12, 2020 11:14 pm
I test them more then most sellers 3 hours of testing is already quite abit most ebay sellers just check if it read the disk and are done says right in there description I do full rips of all UHD disk types
Did you receive a test report with your drive if you did not it is not from me and you can't tell me I don't test my drives good enough
mldardy
I see multiple pages worth of posters reporting problems burning UHD disc. Are you telling me and everyone else that the drives that you test and send out work perfectly with no problems? I find that very hard to believe. You need to get over yourself you are overly defensive. I'm reporting flaws with the drives that are sent out and I'm pretty sure yours have flaws as well.Billycar11 wrote: Mon Jan 13, 2020 12:50 amDid you buy it from me? If you did and are having problems email me I will replace the drive if you just got it Thursday.mldardy wrote: Sun Jan 12, 2020 11:14 pm
first you dont even know if the drive is the problem yet you should test with a replacement disk before saying anyone does not test their drives goodenough.mldardy wrote: Mon Jan 13, 2020 2:30 am
and you said
i test my drives very thoroughly here is a test report from just 1 before sending it outmldardy wrote: Sun Jan 12, 2020 11:14 pm I keep seeing multiple people with different drives getting errors when burning UHD discs in this forum so if you are testing your drives they aren't being tested thoroughly enough. This is kind of ridiculous to sell these products and discs still don't burn correctly.
so you can see i clearly do not send out drives that have problems "burning" as you call it AKA RIPPING/reading.
so again you cant say i dont test my drives good enough you have never bought one from me judging by the review you left in another sellers page
i offered you advice and then you said i don't test my drives or not goodenough when you did not even buy it from me so how am i being overly defensive when your the one making false claims about me
mldardy
I know it's the drive because I've tried to burn about 20 UHD's and almost all of them have failed at some point. This is with me cleaning the discs and all the other troubleshooting that has been suggested.mldardy wrote: Mon Jan 13, 2020 2:30 amI see multiple pages worth of posters reporting problems burning UHD disc. Are you telling me and everyone else that the drives that you test and send out work perfectly with no problems? I find that very hard to believe. You need to get over yourself you are overly defensive. I'm reporting flaws with the drives that are sent out and I'm pretty sure yours have flaws as well.Billycar11 wrote: Mon Jan 13, 2020 12:50 amDid you buy it from me? If you did and are having problems email me I will replace the drive if you just got it Thursday.mldardy wrote: Sun Jan 12, 2020 11:14 pm
I didn't say you don't test your drives. I said no ones drives are perfect or 100% based off all of the report problems in this forum of BURNING discs. Now I'm moving on. If you want to continue to tell me that you test all of your drives fine but please don't tell they work perfectly because they obviously don't.
And yes I did call it burning. So what.
