BD or UHD no longer work
smartieyoung
Re: BD or UHD no longer work
#151 Post by smartieyoung » Wed Jan 30, 2019 6:48 pm
thanks for the update,everything works nice on my end
jayper
#152 Post by jayper » Thu Jan 31, 2019 3:00 am
jayper wrote:
Mon Jan 28, 2019 4:12 am
Product: BD-RE WH16NS40
Revision: 1.02
Firmware date: 2117-03-10 16:50
DEBUG: Code 03DF/02/62194E19F4EC
Fix is working here. Thanks so much!
scdadd
#153 Post by scdadd » Fri Feb 15, 2019 7:56 am
am i suppose to be updating the firmware for my Blu-Ray Drive? if so how do i do it? whats going on here?
#154 Post by Billycar11 » Fri Feb 15, 2019 10:48 am
No usually downgrade what drive model and firmware do you have ?
mldardy
#155 Post by mldardy » Fri Jan 10, 2020 11:52 pm
Hi all I get this issue when on 'A Quiet Place' UHD disc. It keeps displaying this error and then goes back to the main screen where it shows the disc is loaded and ready to be burned. I am using ASUS-BW-16D1HT. Is there a firmware install that I need to get this to work? I just got this unit yesterday.
#156 Post by Billycar11 » Sun Jan 12, 2020 8:22 am
Show us your exact error.
And read this https://www.makemkv.com/forum/viewtopic ... 16&t=19634
mldardy
#157 Post by mldardy » Sun Jan 12, 2020 6:57 pm
#158 Post by Billycar11 » Sun Jan 12, 2020 9:01 pm
Clean the disk , get a replacement disk , get a new drive
mldardy
#159 Post by mldardy » Sun Jan 12, 2020 10:15 pm
Have cleaned it, and bought the drive from one of your sellers and received it on Thursday.
#160 Post by Billycar11 » Sun Jan 12, 2020 10:19 pm
None of them are "my" sellers just recommend according to area before you blame the drive and seller you should to get a replacement disk, for all the drives I sell I include a test report of UHD backup success of a dual layer and triple layer disks
mldardy
#161 Post by mldardy » Sun Jan 12, 2020 11:14 pm
I keep seeing multiple people with different drives getting errors when burning UHD discs in this forum so if you are testing your drives they aren't being tested thoroughly enough. This is kind of ridiculous to sell these products and discs still don't burn correctly.
#162 Post by Billycar11 » Mon Jan 13, 2020 12:50 am
Did you buy it from me? If you did and are having problems email me I will replace the drive if you just got it Thursday.
I test them more then most sellers 3 hours of testing is already quite abit most ebay sellers just check if it read the disk and are done says right in there description I do full rips of all UHD disk types
Did you receive a test report with your drive if you did not it is not from me and you can't tell me I don't test my drives good enough
mldardy
#163 Post by mldardy » Mon Jan 13, 2020 2:30 am
I see multiple pages worth of posters reporting problems burning UHD disc. Are you telling me and everyone else that the drives that you test and send out work perfectly with no problems? I find that very hard to believe. You need to get over yourself you are overly defensive. I'm reporting flaws with the drives that are sent out and I'm pretty sure yours have flaws as well.
#164 Post by Billycar11 » Mon Jan 13, 2020 4:13 am
first you dont even know if the drive is the problem yet you should test with a replacement disk before saying anyone does not test their drives goodenough.
i test my drives very thoroughly here is a test report from just 1 before sending it out
so you can see i clearly do not send out drives that have problems "burning" as you call it AKA RIPPING/reading.
so again you cant say i dont test my drives good enough you have never bought one from me judging by the review you left in another sellers page
i offered you advice and then you said i don't test my drives or not goodenough when you did not even buy it from me so how am i being overly defensive when your the one making false claims about me
mldardy
#165 Post by mldardy » Mon Jan 13, 2020 6:08 am
I know it's the drive because I've tried to burn about 20 UHD's and almost all of them have failed at some point. This is with me cleaning the discs and all the other troubleshooting that has been suggested.
I didn't say you don't test your drives. I said no ones drives are perfect or 100% based off all of the report problems in this forum of BURNING discs. Now I'm moving on. If you want to continue to tell me that you test all of your drives fine but please don't tell they work perfectly because they obviously don't.
And yes I did call it burning. So what.
