Santana IV Bluray failed
sonor
Post by sonor » Wed Jan 30, 2019 1:27 pm
what can i do?
MakeMKV v1.14.2 darwin(x64-release) started
Optical drive "DVD+R-DL PHILIPS SPD6005T P1.0" opened in DASPI v1.5 mode.
Optical drive "BD-RE TSSTcorp BDDVDW SE-506AB TS00" opened in DASPI v1.5 mode.
Optical drive "CD-RW HL-DT-ST CD-RW GCE-8240B 1.05" opened in DASPI v1.5 mode.
DEBUG: Code 01BE/03
Error 'OS error - (iokit/common) can't wire down physical memory' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '0'
Title #00002.mpls was skipped
Error 'OS error - (iokit/common) can't wire down physical memory' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '0'
Title #00000.mpls was skipped
Error 'OS error - (iokit/common) can't wire down physical memory' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '0'
Title #00001.mpls was skipped
Title #00004.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts was skipped
Title #00000.m2ts was skipped
Re: Santana IV Bluray failed
Post by Woodstock » Wed Jan 30, 2019 1:54 pm
This error comes from MacOS. It is a permissions error with a really weird error message.
Older topics with this error message:
https://www.makemkv.com/forum/viewtopic.php?t=17168
https://www.makemkv.com/forum/viewtopic.php?f=4&t=16750
There are many other articles found from other sources when searching for the error text.
Skimming some of the more technical articles, it would seem that you are running applications that are forcing the Mac to reduce the amount of "non-swappable" memory, and the operating system doesn't like that. User applications (like MakeMKV) cannot allocation "wired" memory, but they can reduce how much the operating system has available.
sonor
Post by sonor » Thu Jan 31, 2019 8:46 am
Hello Woodstock,
thanks, i read the two topics. But i am not a computer or a mac specialist. I am only a user.......
So i bought MKV a long, long time ago and it allways going fine. But now........
So i´m never change my system, why? it allways run great.....10.6.8
So please can anyone tell me what to do?
Should i download a older version?
mfg
sonor
Post by Woodstock » Thu Jan 31, 2019 1:45 pm
While you could try an older version, the issue (as I read it) is with what else you are running at the time. Things that use a lot of memory force the operating system to reduce the amount of "wired memory", then anything that comes along that makes requests that require more "wired memory" fail, even though you might have plenty of available program memory.
Did you disable DASPI in your configuration, as suggested by Mike in one of the linked topics?
sonor
Post by sonor » Fri Feb 01, 2019 1:23 pm
Hello Woodstock,
so i found daspi and delet it.
Now it works fine......
thank you
sonor
