Heads up - Support for LG UHD drives
jonghotti
Re: Heads up - Support for LG UHD drives
Post by jonghotti »
Billycar11 wrote: Wed Jan 30, 2019 2:07 am >>going to try a asus on 1.00 later and see what happens
You're going to flash an ASUS with LG firmware 1.00? Why?
demon
Post by demon »
forty2 wrote: Wed Jan 30, 2019 1:40 amDo I need to do anything special to get access to the new features? I've tried first with the version 1.14.2 that I already had installed, then tried again after redownloading and reinstalling. But in both cases, attempts to rip a UHD disk don't work, and I don't see either of these codes anywhere either. I'm sure I'm doing something wrong, but I can't seem to figure out what.
What OS are you on? For me, on Linux, this is what MakeMKV looked like after ripping a disc on my laptop:
https://owncloud.now.ai/index.php/s/UPb1hifvpgog22d
The "DEBUG: Code 03DF/..." line is what you should see if it's successfully able to rip from your drive. My BU40N worked fine with the 1.01 firmware (note the "Revision:" line in the box on the right; that's how the 1.01 firmware on this drive identifies itself).
And no, you don't need to redownload the app. The "Downloading latest SDF" and "Downloading latest HK" items in the log window are the app downloading the data it needs to do the rip. If you see "DEBUG: Code 01BE/...", as mike said, then your drive isn't cooperating. It looks like 1.00 is the latest firmware for that drive on the HLDS site, so it may just not work for a bit yet, but I'm sure mike is working on it.
forty2
Post by forty2 »
demon wrote: Wed Jan 30, 2019 2:43 am What OS are you on? For me, on Linux, this is what MakeMKV looked like after ripping a disc on my laptop:
Thanks a lot for the screenshot; it's very useful to see what it's supposed to look like.
I've tried with both Linux and Windows, and I get the same results in either case. I do have debug logging turned on, but I don't see any Code 01BE or 03DF message.
https://snag.gy/0yermX.jpg
I notice that my Revision field says "0420" and "Firmware date" says "2116-05-24 19:01". I know I'm running the risk of asking questions no one has any way to know the answers to, but is there any reason to think that my firmware might actually be older than 1.00? I wonder if there's any value in trying to run the firmware update utility... On the other hand, I'd hate to ruin my chances of getting it working by doing something stupid...
Thanks again for the help!
demon
Post by demon »
forty2 wrote: Wed Jan 30, 2019 3:53 am I've tried with both Linux and Windows, and I get the same results in either case. I do have debug logging turned on, but I don't see any Code 01BE or 03DF message.
Have you tried starting a backup? You won't see either of the debug code lines until you start a backup of a disc, at which point you'll get "Downloading latest SDF" and "Downloading latest HK" messages. That's the only way you'll know for sure if it works or not.
Yeah, it's hard to know for sure. It's certainly possible that they shipped some hardware with a pre-1.0 firmware image, but I definitely can't confirm. I don't have extensive experience with LG's laptop drives, so dunno if that's ever something they do.
forty2
Post by forty2 »
demon wrote: Wed Jan 30, 2019 4:18 am Have you tried starting a backup? You won't see either of the debug code lines until you start a backup of a disc, at which point you'll get "Downloading latest SDF" and "Downloading latest HK" messages. That's the only way you'll know for sure if it works or not.
Yeah, when I try an actual backup, I get a ton of "ILLEGAL REQUEST: COPY PROTECTION KEY EXCHANGE FAILURE" messages, and it eventually just fails to back up without any Code 03DF/01BE. This screenshot is on Windows, but I get the same results on Linux.
https://snag.gy/IWBG0O.jpg
demon wrote: Wed Jan 30, 2019 4:18 am Yeah, it's hard to know for sure. It's certainly possible that they shipped some hardware with a pre-1.0 firmware image, but I definitely can't confirm. I don't have extensive experience with LG's laptop drives, so dunno if that's ever something they do.
Makes sense. I guess I'll have to decide if I'm feeling lucky or not :) Thanks again!
jonghotti wrote: Wed Jan 30, 2019 2:43 am
no sleep bug i have had it like this for months i mostly playback disks not rip them
jonghotti
Post by jonghotti »
You and that sleep bug :-)
So it appears as of today's surprise update makeMKV users can be confident in the following models/firmwares working wonderfully:
WH16NS60 firmware 1.00
BU40N firmware 1.00, A101, 1.02? I've only had time to verify 1.00 but I've got no less than five flavors of BU40N firmware to go through.
Needs more work:
WH16NS60 firmware 1.01 (log will fill with illegal request: copy protection key exchange failure - key not present) and then error out
BU50N firmware ?? (I have a few of these to go through)
BP60NB10 firmware 1.00 (this spews out the key exchange failure message along with many many hash check this file is corrupt messages which are obviously bogus)
Way to go Mike though, this is huge.
And of course for those people needing a WH16NS60 or BU40N with or without external enclosures (the one i've got for the BU40N is super duper cool) please email or text me.
Post by mike admin »
I want your firmware!!!!
Please navigate to MakeMKV data directory (location can be looked up in preferences). Inside you will find one or more files named dump_SD_xxxxx.tgz . Please send them all to support@makemkv.com . Thanks!
jonghotti
Post by jonghotti »
I’ve got one to send you that’s been growing for awhile. Sure hope there’s a way to make the 60/10 useful.
well i tried wh16ns60 1.00 on an asus with the new feature enabled it works fine no failed key exchanges like before but im just wondering if there ever could be some sort of problem from this like if aacs 2.x is ever cracked how would these drives handle it since they have no encryption chip.
jonghotti
Post by jonghotti »
mike admin wrote: Tue Jan 29, 2019 9:00 pm Today the support for "official UHD" drives was finally enabled (not as smooth as it was hoped). As of today most "official" drives are supported, EXCEPT ones with latest firmware. If you have an "UHD official" drive, you should get one of two messages:
Code 03DF - your drive is working fine, you can make UHD backup with it
Code 01BE - your drive firmware version is not yet supported.
The proper explanation is coming soon. Thanks for the patience!
And according to Hitachi LG the official UHD drives are WH/BH16NS60, BU40N and BP60NB10 they’re easy to spot they have the Ultra HD Blu Ray logo on the bezel as opposed to the standard Blu Ray logo.
forty2
Post by forty2 »
mike admin wrote: Wed Jan 30, 2019 6:55 am I want your firmware!!!!
Done. I'll also leave everything as-is for now so I don't risk losing something that may be important. Thanks again for all the hard work; it's very appreciated!
mattyj2001
Post by mattyj2001 »
I have a BU40N that is _not_ working with firmware 1.01, but it seems to be some other weird kind of firmware, maybe? The Drive Information box in MakeMKV reports this (on a Mac):
OS device name: /dev/rdisk2
Product: BD-RE BU40N
Revision: 1.01
Serial number: KZPHCCG2136
Firmware date: 2117-12-22 12:21
Bus encryption flags: 1F
Highest AACS version: 66
But in the log window it reports:
"Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.01d" opened in OS access mode."
Firmware 1.01d? Whatever that is ... Also, confirmed I have the latest keys_hashed.txt in my data directory and I am attempting to rip a disk that is known to work (2001. I feel like we're all the same kind of sci-fi nerds.)
Not sure if it's possible/practical to downgrade/sidegrade the firmware.
jonghotti
Post by jonghotti »
Don’t worry about the “d” it’s always reported that way from OS X (ok for ASUS drives at least).
What happens you start a rip?
Xavier24
Post by Xavier24 »
Hello everyone
Congratulations to Mike for this big job as the whole team.
I unfortunately have a LG BU40N reader with a firware in v1.02 and I will have to be a little more patient because I have the error code 01BE / 03 as Mike says.
I know that Mike works for us so we will wait a little bit even sinous are a little impatient. 😉
