Please help.
Current profile: BD-R SRM
Manufacturer: LGHL-04P
Product: LG HL-04P MT8575
Revision: 2001
Serial number: MT8575 Firmware
Disc Information
Data capacity: 38.19 Gb
Type: Blu-ray
Label: LORD OF THE RINGS FELLOWSHIP
I am gettng the following error:
MakeMKV v1.5.8 win(x86-release) started
Error 'Scsi error - ILLEGAL REQUEST:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occured while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
Can't read AACS VID from disc - most likely current AACS hos
setarip_old
Re: Can't read AACS VID from disc - most likely current AACS
Hi!
Is your source disc the original, commercial BluRay or, perhaps, a backup copy made from an .ISO image file created by AnyDVD, or something else?
- Contact:
Is your disc readable otherwise? Can you make an encrypted disc backup by selecting "backup" and unselecting "decrypt video files" ?
Yes the disk is otherwise readable.
setarip_old
And again, is your source disc the original, commercial BluRay or, perhaps, a backup copy made from an .ISO image file created by AnyDVD, or something else?
It is an original commercial disk that I rented from Blockbuster.
setarip_old
Such a disc is not appropriate for discussion here...that I rented from Blockbuster
