BD or UHD no longer work
Re: BD or UHD no longer work
Post by mike admin »
The "03" update was just released. You should get the "DEBUG: Code 03DF/03/XXXXXXXXXXXX" and everything should just work. Please reply if it doesn't. Make sure to restart MakeMKV and let it download the updates, if you still are getting "03DF/02" code instead of "03DF/03".
ESPNY wrote: Tue Jan 29, 2019 5:49 pm I definitely recommend not to update the firmware.
Yes, do NOT update the fw to 1.03
GazzaC
Post by GazzaC »
Yep, all seems to work now Mike, previously getting the DEBUG 03DF message. Congrats!
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
Serial number: K9NI1FI4443
Firmware date: 2117-03-31 14:26
Bus encryption flags: 1F
Highest AACS version: 65
ez2cwhy
Post by ez2cwhy »
mike admin wrote: Tue Jan 29, 2019 6:36 pm
Serves me right for skimming the forum and not reading thoroughly. Apparently the FW upgrade is a one-way trip. So, what did I just screw up...the ability to play UHD Blurays or something even worse?
ez2cwhy wrote: Tue Jan 29, 2019 7:17 pm Serves me right for skimming the forum and not reading thoroughly. Apparently the FW upgrade is a one-way trip. So, what did I just screw up...the ability to play UHD Blurays or something even worse?
The bad news - you lost ability to read UHD discs. The good news - not for long, there will be update "soon" that will enable reading UHD discs on 1.03 fw.
xmenw
Post by xmenw »
mike admin wrote: Tue Jan 29, 2019 7:31 pm
Wow that would be nice. I had downgraded firmwares on 2 drives so far. But this would be sweet!
Thank you for your hard work Mike!
DoXer
Post by DoXer »
My workaround, which seems to work:
1. Copy the BD or UHD with FileManager to the disk.
2. Open Index.bdmv (for UHD) with "File Open"
3. Rip it.
morbius
Post by morbius »
Can the meaning of the debug code be explained for those who see it but have no problems with back-ups working? Having seen this thread I just tried 1.14.2 in case I had a problem and all was fine, except I did have this in the log:
DEBUG: Code 03DF/03/F0ED16432FAA
BlueMac77
Post by BlueMac77 »
Continued to run tests on MakeMKV v1.14.2 on Mac OSX just to be sure and all working fine in relation to my earlier post. A Big Thanks to Mike for staying on Top of things. Hope all will be okay for everyone.
morbius wrote: Tue Jan 29, 2019 7:46 pm Can the meaning of the debug code be explained for those who see it but have no problems with back-ups working? Having seen this thread I just tried 1.14.2 in case I had a problem and all was fine, except I did have this in the log:
This is really a big thing that was in development over a year, and it will be explained in detail very soon. For now, as it was said earlier - this code means that you are very lucky :)
forceawakens
Post by forceawakens »
Mike for those of us still not able to back up discs because of a debug code there will be a new firmware coming from MakeMKV that will fix the problem?
I’m still having the problem.
stefanop
Post by stefanop »
Sorry, where do you find the updated version of MakeMKV? I still find 14.2 only dated dec 1st.
stefanop
Post by stefanop »
Ok, I tried closing and reopening MakeMKW and launch a backup. It still appears DEBUG: Code 03DF/03/F0ED16432FAA but it works and it performs a regular backup.
Thank you very much Mike!!!
forceawakens wrote: Tue Jan 29, 2019 8:45 pm I’m still having the problem.
With 03DF/03 code??? Please write to support@makemkv.com .
alxscott
Post by alxscott »
Download updated and working for 1 UHD, 1 BR and 1 DVD. Thanks Mike :)
