Avatar 3D Problems
Everything related to Blu-ray 3D and 3D MKV files
mhconley
Avatar 3D Problems
#1 Post by mhconley » Tue Jan 29, 2019 3:45 am
This is my first try at 3D. I am trying to create a 3D rip of the Avatar 3D blu-ray.
I am copying the Avatar - 36 chapter(s) , 44.9 GB 00001.m2ts stream. have Video Mpeg4-MVC-3D checked along with Audio DTS-HD MA Surround 5.1 English and DTS Surround 5.1 English. Everything else is unchecked.
My drive is a Pioneer BDR-XD07J-UHD and my PC is an Intel NUC. The rip completes and I have a perfect 42.2GB 2D mkv copy. The same thing happens if I choose the 00002.m2ts Avatar - 1 chapter(s) , 44.9 GB stream.
Why am I not getting a 3D rip?
Thanks,
Martin
mhconley
Re: Avatar 3D Problems
#2 Post by mhconley » Tue Jan 29, 2019 7:31 pm
I tried Gravity 3D and got the same result - a perfect 2D copy. I am using MakeMKV v 1.14.2.
Any ideas?
Thanks,
Martin
mhconley
#3 Post by mhconley » Tue Jan 29, 2019 8:11 pm
I think these are correctly being ripped in 3D and I'm having issues with playback.
Avatar:
Video
ID in the original source medium : 4113 (0x1011)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Stereo High@L4.1 / High@L4.1
MultiView_Count : 2
MultiView_Layout : Both Eyes laced in one block (left eye first)
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2 h 41 min
Bit rate : 31.8 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.639
Stream size : 35.9 GiB (85%)
Language : English
Default : No
Forced : No
Original source medium : Blu-ray
Gravity:
Video
Format : AVC
MultiView_Count : 2
Format settings : CABAC / 2 Ref Frames
Format settings, RefFrames : 2 frames
Duration : 1 h 30 min
Bit rate mode : Variable
Bit rate : 34.6 Mb/s
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.697
Stream size : 22.0 GiB (90%)
Language : English
Default : No
Forced : No
Thanks,
Martin
HookedonHD
#4 Post by HookedonHD » Wed Jan 30, 2019 4:21 am
I am so glad this is alive! I have the same problem with both of those movies and then some. I dug up bunch of my old 3D Blu-rays as well and got myself an nvidia shield and a snology ds918+. My TV is an LG OLED656CP and I have 2 movies that have been ripped along time ago God knows with what but they work fine with Plex and Emby (Rogue One and Assassin's Creed). Unfortunately, I have ripped Avatar, gravity, clash of the titans with no luck so far. I thought maybe it was plex then I installed emby and I am getting the same results. Any guidance would be appreciated it! Thanks in advance!
mhconley
#5 Post by mhconley » Wed Jan 30, 2019 6:32 pm
HookedonHD wrote: Wed Jan 30, 2019 4:21 am I am so glad this is alive! I have the same problem with both of those movies and then some. I dug up bunch of my old 3D Blu-rays as well and got myself an nvidia shield and a snology ds918+. My TV is an LG OLED656CP and I have 2 movies that have been ripped along time ago God knows with what but they work fine with Plex and Emby (Rogue One and Assassin's Creed). Unfortunately, I have ripped Avatar, gravity, clash of the titans with no luck so far. I thought maybe it was plex then I installed emby and I am getting the same results. Any guidance would be appreciated it! Thanks in advance!
I would bet that those older 3D rips are SBS half-HD and not frame packed full-HD. I'd like to keep the full-HD quality of the original. So far I have not found a combination that will play them as 3D on my LeEco Umax85. The TV has a 3D setting with choices of SBS, T&B and Auto. I do have an Xbox One X and a Philips UHD Blu-ray player. None of these will correctly play a frame packed full-HD 3D mkv. They do however, play SBS half-HD 3D.
I used BD3D2MK3D to reencode my MakeMKV MVC 3D rips into SBS mkv files. Below is what MediaInfo reports for each file. The amazing thing is the SBS reencoded version is 14.1GB while the original frame packed version is 44.3GB. Quality looks pretty good to my eyes.
MakeMKV file:
Video
Format : AVC
MultiView_Count : 2
Color space : YUV
Bit depth : 8 bits
Reencoded file:
Video
Format : AVC
Format profile : High@L4
MultiView_Count : 2
MultiView_Layout : Side by Side (left eye first)
Format settings : CABAC / 4 Ref Frames
Format settings, RefFrames : 4 frames
Color space : YUV
Bit depth : 8 bits
Martin
HookedonHD
#6 Post by HookedonHD » Sun Feb 03, 2019 1:59 am
Weird I didn't get an email notification for your reply. Anyways, that's awesome! I just downloaded that program and I am going to give it a shot as soon as my workstation is free. Did you try using handshake or anything to make the file even smaller by any chance? I have an atmos setup however, I noticed most of these movies are like 5.1 so, I was wondering if there is a way of keep the quality with the sound and shrink the file size to a much smaller size and keep the integrity? Thanks in advance!
