BD or UHD no longer work
smartieyoung
Re: BD or UHD no longer work
Post by smartieyoung » Tue Jan 29, 2019 3:08 pm
Im sorry that its not working for you,I was hoping my method would at least help someone the system must really be messed up I hope mike has a solution at somepoint.good luck on your end .feel free to DM me if you want.
kfreeb
Post by kfreeb » Tue Jan 29, 2019 3:25 pm
I have no idea how AACS works, other than it is an encryption key that MakeMKV uses, but the common problem seem to affect systems that have not updated to the new version of MakeMKV as well.
Could it be that the AACS encryption key accesses an online service somewhere and that access has been revoked, or terminated? Just saying that this hit allot of drives all at once, whether you were running old or new version of MakeMKV.
Mac Studio M3 Ultra
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
ESPNY
Post by ESPNY » Tue Jan 29, 2019 3:35 pm
I have reinstalled 1.14.2 with the current beta key, NOT WORKING!
Edit:
Installed makemkv on my laptop, same problem/error.
jagrjones
Post by jagrjones » Tue Jan 29, 2019 4:03 pm
DEBUG: Code 03DF/02/62194E19F4EC
Using WH16NS40 with 1.02 firmware.
ez2cwhy
Post by ez2cwhy » Tue Jan 29, 2019 4:31 pm
For everyone who has an LG WH16NS40 drive, consider upgrading your drive's FW. I too had the exact same problem as highlighted in this thread while I was on version 1.02. Today I upgraded to 1.03 and it completely resolved the issue I was seeing.
https://www.lg.com/us/support-product/lg-WH16NS40
alxscott
Post by alxscott » Tue Jan 29, 2019 4:38 pm
Posting incase it helps or needed:
Debug Code 03DF/02/E064BA3E3F81
Manufacturer: ASUS |Product: BW-16D1HT |Revision: 3.01 |Firmware date: 2117-03-31 14:26
MakeMKV Version: 1.14.2 Linux GNU
Any log files I had have been emailed to support@makemkv.com
jagrjones
Post by jagrjones » Tue Jan 29, 2019 5:47 pm
If you do this, don't you lose your ability to read UHD discs?
ESPNY
Post by ESPNY » Tue Jan 29, 2019 5:49 pm
I definitely recommend not to update the firmware.
SniperStan
Post by SniperStan » Tue Jan 29, 2019 5:58 pm
Posting to increase Issue Data-set,
I recieve this error on all my LG blu ray drives, both internal and external.
External Drive:
LG BP50NB40 1.0
DEBUG: Code 03DF/02/F1E492503DA6
Throws code but appears to operate normally otherwise.
Internal Drives (3 Total):
LG WW14NS40 1.02
DEBUG: Code 03DF/02/10F16E86E12A
Hangs on decrypting for exactly 15 minute and then behaves normally.
can provide logs if you need them.
Cheers Mike!
teckman
Post by teckman » Tue Jan 29, 2019 6:03 pm
Everyday I check and it still hangs with this error:
MakeMKV v1.14.2 win(x64-release) started
DEBUG: Code 03DF/02/ABC4C72B168F
I have even reset my entire computer by doing a clean install of Windows 10 and then reinstalling Make MKV. Nothing helps. It was working just fine last week. I've been having this same error and hanging issue since Saturday January 26, 2019. I keep hoping it will get fixed. Any relief in sight?
I am using an LG Slim portable Blu-ray/DVD writer. Model BP50NB40.
cyperous
Post by cyperous » Tue Jan 29, 2019 6:15 pm
I would also recommend not upgrading the firmware, when I got my drive original I had firmware 1.03 and it refused to read any UHD disc until I downgraded to version 1.02.
On a side note, this issue is definitive a problem with MakeMKV because the same drive under windows works perfectly with AnyDVD and DeUHD under windows for UHD disc. I also have no problems with AnyDVD ripping BD disc either.
Mike if you're reading this please fix MakeMKV, something has changed and I can't rip UHD or BD's with this drive, which is unfortunate because I like using MakeMKV for its ability to work under Linux. For now my system is dual booted with Windows with AnyDVD, which is working perfectly with this drive.
Please fix your software, I have a paid key and really like using it. I'm still continuing to use MakeMKV to create the Mkv's from a ripped folder structure. But I would prefer to make the rip backup using MakeMKV.
falconfan
Post by falconfan » Tue Jan 29, 2019 6:16 pm
Makemkv was working fine until this morning. Every UHD disc I tried to open failed. I had previously backed up John Wick 4K without a problem. Tried it again this morning. Got the following:
DEBUG: Code 03DF/02/E3767A939283
Saved AACS dump file as C:\Users\Bob/.MakeMKV/MKB20_v61_John_Wick_EDAF.tgz
Same for any other disc I try.
MKB20_v60_Patriots_Day_D78F.tgz
(129.09 KiB) Downloaded 1212 times
MKB20_v60_Magnificent_Seven,_The_(2016)_418D.tgz
(105.2 KiB) Downloaded 1309 times
(97.14 KiB) Downloaded 1490 times
IIIMADDINIII
Post by IIIMADDINIII » Tue Jan 29, 2019 6:19 pm
DEBUG: Code 03DF/02/E064BA3E3F81
dred1367
Post by dred1367 » Tue Jan 29, 2019 6:25 pm
Using: WH14NS40 1.02d on a mac, not possible to update firmware from a mac.
eriksdam
Post by eriksdam » Tue Jan 29, 2019 6:27 pm
A quick workaround until a solution is found: I downloaded AnyDVD (the trial version will work), and now I can at least rip normal Blu Rays....
