BD or UHD no longer work
scoobyrich
Re: BD or UHD no longer work
Post by scoobyrich » Mon Jan 28, 2019 9:37 pm
Same issue here:
DEBUG: Code 03DF/02/8B3B7ED27530
sickb
Post by sickb » Mon Jan 28, 2019 9:43 pm
Same issue, LG with Asus FW:
DEBUG: Code 03DF/02/96929CF53B04
jon96789
Post by jon96789 » Mon Jan 28, 2019 10:31 pm
I am getting the same issue... It stopped working on Saturday. I get a DEBUG error which i mentioned earlier and takes forever to scan the disc. It appears to be a problem with the de-encryption (does MakeMKV call home to rip discs? It could be the reason). No matter what Blu-Ray disc I use (even earlier ones that were ripped), the programs hangs.
If I enable SlySoft's AnyDVD and use it to decrypt the disc, then there are no issues. The program scans the disc and proceeds normally (after the MakeMKV warning about another program decrypting the disc). I noted that AnyDVD must be launched before MakeMKV for it to work. If not, AnyDVD does not turn on.
Another thing I noticed... When MakeMKV crashes, it seems to corrupt Windows 10 Pro. I cannot shut down my PC, it just hangs in the SHUTTING DOWN screen. I have to manually power down the PC. If I use AnyDVD to decrypt the disc, the PC will shut down normally. If I do not use MakeMKV, the PC behaves normally and shuts down as well.
I am using a LG HL-DT-ST BD-RE BH16NS40 Blu-Ray drive connected via SATA cable, not a USB External drive.
[rab]
Post by [rab] » Mon Jan 28, 2019 11:54 pm
I have noticed the same thing as jon96789, my Windows 7 machine will also hang and not complete its shutdown sequence.
adidamac
Post by adidamac » Tue Jan 29, 2019 12:11 am
Same issue here.
DEBUG: Code 03DF/02/62194E19F4EC
Windows starts acting up, have to do a manual restart. Further, after restart, windows stops detecting the BD drive. Unplugging/replugging the SATA and power cables ends up with a blue screen of death and then eventually after another hard restart windows starts operating normally.
Glad to see I'm not alone in the windows corruption issue (thanks for sharing jon96789)
kfreeb
Post by kfreeb » Tue Jan 29, 2019 12:41 am
Not saying it is so, but!
Seems to be acting allot like a virus, possibly damaging the Blu-ray drive firmware?
Mine seemed to get worse over a 4 day period, till it no longer could decrypt blu-ray disks.
Maybe something for Mike to look into?
Just a thought!
Mac Studio M3 Ultra
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
teckman
Post by teckman » Tue Jan 29, 2019 1:06 am
Hi
Mine still does not work. It hangs with the same error: DEBUG: Code 03DF/02/62194E19F4EC.
jnaroberts
Post by jnaroberts » Tue Jan 29, 2019 1:20 am
DEBUG: Code 03DF/02/10F16E86E12A
CalamityOne
Post by CalamityOne » Tue Jan 29, 2019 1:42 am
BluRay: My Big Fat Greek Wedding, message:
UPDATE Weds 30-Jan-2019: software seems to no be able to rip bluray without issue
endlessblockade
Post by endlessblockade » Tue Jan 29, 2019 2:08 am
I am not having any issues ripping both UHD or BD but did notice a debug code show up in my log on Saturday:
DEBUG: Code 01BE/02
I am using 2 ASUS BC-12B1ST drives both hooked up via sata. I see a lot posts mentioning the ASUS BW-16D1HT and the LG WH16NS40 so I wonder if this is only affecting certain drive models.
wags97
Post by wags97 » Tue Jan 29, 2019 2:25 am
I cannot even get DVDs to convert - DEBUG: Code 03DF/02/10F16E86E12A. Using an LG WH14NS40 drive.
Someguy1234
Post by Someguy1234 » Tue Jan 29, 2019 2:50 am
I'm getting the same problem. I'm on an LG BH16NS40 drive.
I get this error and every time I try to rip a disc it makes a dump file.
DEBUG: Code 03DF/02/DA23CAE0BD2F
Saved AACS dump file as C:\Users\blah/.MakeMKV/MKB20_v61_Wonder_Woman_D99B.tgz
BrolicBeast
Post by BrolicBeast » Tue Jan 29, 2019 3:03 am
Definitely getting the debug code:
Someguy1234
Post by Someguy1234 » Tue Jan 29, 2019 3:30 am
I'm using an LG BH16NS40 drive with ASUS firmware (v1.02), and here's the errors I keep getting.
Saved AACS dump file as C:\Users\justi/.MakeMKV/MKB20_v61_Christine_(1983)_757F.tgz
Saved AACS dump file as C:\Users\justi/.MakeMKV/MKB20_v66_AIRCRAFT_CARRIER_46A4.tgz
BrianA2060
Post by BrianA2060 » Tue Jan 29, 2019 3:42 am
MakeMKV v1.14.2 win(x64-release) started
DEBUG: Code 03DF/02/76A0C3CD522E
I started getting this DEBUG code yesterday. Ripping a DVD in a blue ray player. This was never a problem before.
I did reboot my system twice before submitting this report.
