Since there is no way at the current moment to retain Dolby Vision during the process of making an MKV, I was thinking about making an ISO backup of my UHD's to ensure that I can keep the Dolby Vision file in case this functionality gets added in future versions of MakeMKV.
Does anyone know if making a ISO backup of a disc using MakeMKV retains the Dolby Vision (and Dolby Atmos) file?
Thank you in advance!
ISO Backups & Dolby Vision + Atmos
Re: ISO Backups & Dolby Vision + Atmos
MakeMKV does not do ISO backups. It writes out BD file structure (optionally decrypted), but that isn't an ISO.
st4evr
In addition, this has been discussed in detail multiple times over in several existing posts. Using the forum search function could also be helpful in finding this information.
Example:
https://www.makemkv.com/forum/viewtopic ... ppo#p68906
There is even a whole thread about it:
https://www.makemkv.com/forum/viewtopic ... 12&t=17235
And there are no individual DV and/or DA “files” sitting somewhere. It does not work that way. Recommended you read that DV thread if possible, as it provides useful information regarding DV. A Google search can also provide additional information as well and also instructions on how to create ISO files from decrypted discs/BD folder structures.
Example:
