ISO Backups & Dolby Vision + Atmos
GranArcanum
Post by GranArcanum »
Since there is no way at the current moment to retain Dolby Vision during the process of making an MKV, I was thinking about making an ISO backup of my UHD's to ensure that I can keep the Dolby Vision file in case this functionality gets added in future versions of MakeMKV.
Does anyone know if making a ISO backup of a disc using MakeMKV retains the Dolby Vision (and Dolby Atmos) file?
Thank you in advance!
Re: ISO Backups & Dolby Vision + Atmos
MakeMKV does not do ISO backups. It writes out BD file structure (optionally decrypted), but that isn't an ISO.
st4evr
Post by st4evr »
In addition, this has been discussed in detail multiple times over in several existing posts. Using the forum search function could also be helpful in finding this information.
Example:
https://www.makemkv.com/forum/viewtopic ... ppo#p68906
There is even a whole thread about it:
https://www.makemkv.com/forum/viewtopic ... 12&t=17235
And there are no individual DV and/or DA “files” sitting somewhere. It does not work that way. Recommended you read that DV thread if possible, as it provides useful information regarding DV. A Google search can also provide additional information as well and also instructions on how to create ISO files from decrypted discs/BD folder structures.
