BD or UHD no longer work
Chipless
Re: BD or UHD no longer work
My streak of unluckiness continues. Still cannot backup any discs, code string is:
DEBUG: Code 03DF/02/E064BA3E3F81
And then the program has a fatal error and only thing I can do is close it.
jayeroff
No longer working for me either.
DEBUG: Code 03DF/02/F0ED16432FAA
jayeroff
I'm unable to rip BD or UHD. Problem started over the weekend, and still not working today.
xmenw
Movie A Simple Favor (triple layer ~85gb)
DEBUG: Code 03DF/02/62194E19F4EC
OS device name: H:
Product: BD-RE WH16NS40
Revision: 1.02
Firmware date: 2117-03-10 16:50
Highest AACS version: 66
OS device name: H:
Revision: 1.02
jdunbar
I still can't use Makemkv on bluray discs. It just hangs forever.
MakeMKV v1.14.2 win(x64-release) started
DEBUG: Code 03DF/02/76A0C3CD522E
Evo01
OS device name: I:
Revision: 1.02
Highest AACS version: 65
Disc Information
Label: JOHN_WICK_CHAPTER_2
Timestamp: 2017-04-24 20:54:57
Data capacity: 46.48 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
OS device name: I:
Revision: 1.02
Disc Information
Disc type: BD-ROM
Number of layers: 2
jdunbar
I still can't use Makemkv on Stargate Continuum bluray. It just hangs forever.
ElJimador
Another victim...
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.00
Serial number: SIK9FH1LF483
Firmware date: 2115-11-03 11:10
Bus encryption flags: 1F
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.00
cyperous
I started getting this a few days ago.
It would normally print DEBUG: Code 03DF on hundreds of UHD rips and BD rips.
then it would go directly into a rip without issues, no hanging.
I haven't changed anything and now it's printing DEBUG: Code 03DF/02/62194E19F4EC and it just hangs, the first time it did this it started ripping a few minutes later. Now it's just failing.
Drive: HL-DT-ST BD-REWH16NS40 1.02 Internal (SATA)
OS: Windows and Linux (Ubuntu)
I'm using AnyDVD until this is all sorted out.
BlueMac77
So far working fine here on ripping blu-rays before or after the DEBUG: code 03DF announcement. On a Mac OS Mavericks, 2 versions of MakeMKV installed, v1.12.2 and v1.14.1 versions. I haven’t tried MMKV v1.14.2 yet. Using 3 Pioneer BD drives alternately.
Pioneer BDR-207 DBK connected externally via USB 3.0
Pioneer BDR-2209 UBK connected externally via Firewire 400
Pioneer BDR-211 UBK internal
I seldom use Windows 7 installed in my Mac but tested ripping blu-rays and works fine using MakeMKV v1.14.0 on a Pioneer BDR-207 via USB 2.0
cyperous
Reply to my existing post.
piyama
I'm having the following error when I attempt to open a disc
DEBUG: Code 03DF/02/5568F5F3382A
disc is Freaks and Geeks DVD disc 1
GazzaC
Alas, still no joy for me. Internal drive too so no USB to muddy the waters, will leave the drive hunting to see if it eventually does anything useful
....been 15 mins and counting...after 30 mins I gave up. Another reboot required to get the system working properly.
Only slight difference from yesterday (apart from the DEBUG code displaying) is that its now hanging on parsing file :/AACS/MKB_RO.inf
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
Backing up disc into folder "E:/4K/JWFK_UPK1"
Downloading latest SDF to C:\Users\Media/.MakeMKV ...
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
eriksdam
Same issue.
Stuck at :/AACS/MKB_RO.inf...
Win 10, ASUS BW-16D1HT
- Erik
- Erik
[rab]
The most recent attempt to open a BD with my Topelek USB 3.0 external reader/writer has been running for over 21 hrs and throwing timeout errors, so i don't have the AACS dump log to give yet until it finally fails and writes to that folder.
It goes on that way for quite a long time (as you can imagine from running for so long and throwing errors).
Evaluation version, 28 day(s) out of 30 remaining
Downloading latest SDF to C:\Users\alex/.MakeMKV ...
DEBUG: Code 03DF/02/08300AB0DD2E
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '22115880960'
