Problems with the Optiarc BC-5600S Drive?
Ryan727
Post by Ryan727 » Fri Aug 06, 2010 2:49 pm
Has anyone had problems with this drive? I believe I have the most current firmware version 103B. The last three Blu-rays I have tried to copy to my hard drive wont copy. I tried to copy them without using Makemkv and it still doesn't work. My computer registers the disc and will start the copying process but then fails about 1/3 of the way through. All three discs are Lionsgate films, is it the disc encryption that’s preventing the drive from copying the movies. All three disc play fine in my PS3 so I don't think they are faulty discs. Any ideas?
Re: Problems with the Optiarc BC-5600S Drive?
Post by mike admin » Sat Aug 07, 2010 7:51 am
Please enable the debug log per instructions at http://www.makemkv.com/faq/item/8/catid/6 and post it here.
Ryan727
Post by Ryan727 » Sun Aug 08, 2010 6:18 am
Here is the log, it seems to be getting hung up on one particular .m2ts file. This is also the case with the other films.
Ryan727
Post by Ryan727 » Wed Aug 11, 2010 4:37 pm
Here is the log from another Lionsgate film, Makemkv can't even open this particular disc nor can I copy the disc to my hard drive.
Post by mike admin » Thu Aug 12, 2010 9:22 am
Can you copy that file or entire disc to harddrive in finder?
Ryan727
Post by Ryan727 » Thu Aug 12, 2010 1:36 pm
Nope, I've tried to copy the entire disc as well as the specific movie file and both fail. All discs play fine in my PS3 and I have copied other Blu-ray's. I don't know if it has something to do with all three discs being Lionsgate films?
Post by mike admin » Tue Aug 17, 2010 8:38 am
Ryan727 wrote:Nope, I've tried to copy the entire disc as well as the specific movie file and both fail.
For some reason your drive physically fails to read them. I can only suggest to update the drive firmware if possible.
