BD or UHD no longer work
Chipless
Re: BD or UHD no longer work
#61 Post by Chipless » Mon Jan 28, 2019 5:21 pm
My streak of unluckiness continues. Still cannot backup any discs, code string is:
DEBUG: Code 03DF/02/E064BA3E3F81
And then the program has a fatal error and only thing I can do is close it.
jayeroff
#62 Post by jayeroff » Mon Jan 28, 2019 5:56 pm
No longer working for me either.
DEBUG: Code 03DF/02/F0ED16432FAA
jayeroff
#63 Post by jayeroff » Mon Jan 28, 2019 6:00 pm
I'm unable to rip BD or UHD. Problem started over the weekend, and still not working today.
xmenw
#64 Post by xmenw » Mon Jan 28, 2019 6:24 pm
Movie A Simple Favor (triple layer ~85gb)
DEBUG: Code 03DF/02/62194E19F4EC
OS device name: H:
Product: BD-RE WH16NS40
Revision: 1.02
Firmware date: 2117-03-10 16:50
Highest AACS version: 66
jdunbar
#65 Post by jdunbar » Mon Jan 28, 2019 6:34 pm
I still can't use Makemkv on bluray discs. It just hangs forever.
MakeMKV v1.14.2 win(x64-release) started
DEBUG: Code 03DF/02/76A0C3CD522E
Evo01
#66 Post by Evo01 » Mon Jan 28, 2019 6:37 pm
OS device name: I:
Revision: 1.02
Highest AACS version: 65
Disc Information
Label: JOHN_WICK_CHAPTER_2
Timestamp: 2017-04-24 20:54:57
Data capacity: 46.48 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
jdunbar
#67 Post by jdunbar » Mon Jan 28, 2019 6:38 pm
I still can't use Makemkv on Stargate Continuum bluray. It just hangs forever.
ElJimador
#68 Post by ElJimador » Mon Jan 28, 2019 6:38 pm
Another victim...
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.00
Serial number: SIK9FH1LF483
Firmware date: 2115-11-03 11:10
Bus encryption flags: 1F
cyperous
#69 Post by cyperous » Mon Jan 28, 2019 6:49 pm
I started getting this a few days ago.
It would normally print DEBUG: Code 03DF on hundreds of UHD rips and BD rips.
then it would go directly into a rip without issues, no hanging.
I haven't changed anything and now it's printing DEBUG: Code 03DF/02/62194E19F4EC and it just hangs, the first time it did this it started ripping a few minutes later. Now it's just failing.
Drive: HL-DT-ST BD-REWH16NS40 1.02 Internal (SATA)
OS: Windows and Linux (Ubuntu)
I'm using AnyDVD until this is all sorted out.
BlueMac77
#70 Post by BlueMac77 » Mon Jan 28, 2019 7:01 pm
So far working fine here on ripping blu-rays before or after the DEBUG: code 03DF announcement. On a Mac OS Mavericks, 2 versions of MakeMKV installed, v1.12.2 and v1.14.1 versions. I haven’t tried MMKV v1.14.2 yet. Using 3 Pioneer BD drives alternately.
Pioneer BDR-207 DBK connected externally via USB 3.0
Pioneer BDR-2209 UBK connected externally via Firewire 400
Pioneer BDR-211 UBK internal
I seldom use Windows 7 installed in my Mac but tested ripping blu-rays and works fine using MakeMKV v1.14.0 on a Pioneer BDR-207 via USB 2.0
cyperous
#71 Post by cyperous » Mon Jan 28, 2019 7:02 pm
Reply to my existing post.
piyama
#72 Post by piyama » Mon Jan 28, 2019 8:10 pm
I'm having the following error when I attempt to open a disc
DEBUG: Code 03DF/02/5568F5F3382A
disc is Freaks and Geeks DVD disc 1
GazzaC
#73 Post by GazzaC » Mon Jan 28, 2019 8:41 pm
Alas, still no joy for me. Internal drive too so no USB to muddy the waters, will leave the drive hunting to see if it eventually does anything useful :cry: ....been 15 mins and counting...after 30 mins I gave up. Another reboot required to get the system working properly.
Only slight difference from yesterday (apart from the DEBUG code displaying) is that its now hanging on parsing file :/AACS/MKB_RO.inf
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
Backing up disc into folder "E:/4K/JWFK_UPK1"
Downloading latest SDF to C:\Users\Media/.MakeMKV ...
eriksdam
#74 Post by eriksdam » Mon Jan 28, 2019 8:53 pm
Same issue.
Stuck at :/AACS/MKB_RO.inf...
Win 10, ASUS BW-16D1HT
- Erik
[rab]
#75 Post by [rab] » Mon Jan 28, 2019 9:36 pm
The most recent attempt to open a BD with my Topelek USB 3.0 external reader/writer has been running for over 21 hrs and throwing timeout errors, so i don't have the AACS dump log to give yet until it finally fails and writes to that folder.
Evaluation version, 28 day(s) out of 30 remaining
Downloading latest SDF to C:\Users\alex/.MakeMKV ...
DEBUG: Code 03DF/02/08300AB0DD2E
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '22115880960'
It goes on that way for quite a long time (as you can imagine from running for so long and throwing errors).
