BD or UHD no longer work
Comrade_Ruckus
Re: BD or UHD no longer work
Post by Comrade_Ruckus »
just tried an older version of the software and it works but i dont recommend people go and download the older version since it may have some bugs that the new ones have fixed
Rantlers
Post by Rantlers »
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.00
Firmware date: 2115-11-03 11:10
DEBUG: Code 03DF/02/F0ED16432FAA
misterbill
Post by misterbill »
DEBUG: Code 03DF/02/96929CF53B04
Source : BD-RE ASUS BW-16D1HT 3.02
MakeMKV v1.14.2 win(x64-release)
Re installed MakeMKV
Re flashed drive.
Thanks for everything,
Bill
jalsk
Post by jalsk »
I'm having the same issue, app hangs when opening a dvd. Internal LG BD drive - WH16NS40
DEBUG: Code 03DF/02/76A0C3CD522E
Happy to provide a dump if that's helpful.
jayper
Post by jayper »
Product: BD-RE WH16NS40
Revision: 1.02
Firmware date: 2117-03-10 16:50
DEBUG: Code 03DF/02/62194E19F4EC
hughesw
Post by hughesw »
Having trouble with both of my LG internal drives right now.
Product: BD-RE WH16NS60
Revision: 1.00
Firmware date: 2117-04-25 17:56
Code: 03DF/02/4FBA32AEC678
and the second drive:
Revision: 1.02
Onyx1640
Post by Onyx1640 »
Unable to rip Blurays on build v1.14.2.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.00
Drive is connected via SATA to my motherboard. I'll let it error out overnight and send a dump file to support tomorrow.
Debug log started at Mon Jan 28 10:19:20 2019 , written by MakeMKV v1.14.2 win(x64-release)
001005:0000 MakeMKV v1.14.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Billy/MakeMKV_log.txt
005072:0000 Backing up disc into folder "S:/Movies/THE_WOLVERINE"
001011:0000 DEBUG: Code 03DF/02/4FBA32AEC678
DEBUG: Code 2400194817 at 3tu+2QPU[=7Te!Z9e:121263268
DEBUG: Code 0 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 1 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 2 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 3 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 4 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 5 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 2400194817 at 3tu+2QPU[=7Te!Z9e:121263153
DEBUG: Code 0 at z3q2Zsw5q;dm{R\<:213140426
DEBUG: Code 0 at FcF^D,r,a.ZGY1pC:29401014
DEBUG: Code 2147483648 at z3q2Zsw5q;dm{R\<:121265223
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=+WlJarCEjOorMUNPCUCdTFvDX261tVjnn9oMnNVaHtdVSmn5NNduG6cXigKtWP3Dp0cPwwgsO6TywRCfr0xl9/3GcYbETC00UbcU3BWXW+jC8AoDNtRtxSDCalbgoFRCysbMuvRBRCdSPYgWcH0QlzvSviMPfW+XOw==
DCE=pAg5FweKsWPnvzFOWFxOBJWkD/u8Ytt02hCVd9/nqHwtaCyRF2YACn8CU9iNVAqOnHj4mhxSj68rTdK/ck8kjoMURVWngR/iHKZPIQpF3qVZyEqatHOwp2i4Vr43qeEjl+S1zn5ir0nY05Ch+2NDSv+tJCEnTLXiyA==
001003:0020 DEBUG: Code 0 at z3q2Zsw5q;dm{R\<:213134538
003317:0000 Loaded 9 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/generic.svq
SVQ: generic005 builtin/generic.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
001003:0020 DEBUG: Code 0 at FcF^D,r,a.ZGY1pC:121272353
001003:0020 DEBUG: Code 0 at tlj{;\IIvCfOanAM]:29395264
001003:0020 DEBUG: Code 0 at jZgnXs]@$+Bd`RXv:121274331
001003:0020 DEBUG: Code 0 at jZgnXs]@$+Bd`RXv:29398116
001003:0020 DEBUG: Code 0 at )pYKsF6-M{40&1/[qlb:29397679
001003:0020 DEBUG: Code 0 at )pYKsF6-M{40&1/[qlb:121265131
001003:0020 DEBUG: Code 0 at J@5gvt}TIca8)f[\edO^:121265154
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Mon Jan 28 10:22:30 2019
if it matters this asus is crossflashed to wh16ns60 1.00 it would work but with a few failed key exchange errors now i get that. the enclosure is a vantec and chipset it is a asmedia asm1153e b1rk89d7a0 1749
Crazywolf
Post by Crazywolf »
I encountered the "DEBUG: Code 03DF/02/" error this morning trying to convert my Planet of the Apes DVDs: I had to roll back to the previous version of MakeMKV to get around the issue.
I'm happy that merely reinstalling the previous version of the program worked (1.14.1), so I'm looking forward to the release of version 1.14.3
Excellent program by the way!!!
CJ32601@yahoo.com
Post by CJ32601@yahoo.com »
Still getting hung up on debug code
ASUS BW-16D1HT 3.01
DEBUG: Code 03DF/02/E064BA3E3F81
DigDayDude
Post by DigDayDude »
It worked for the one BD after a number of hours opening disc. Restarted PC and attempted to open another BD and now after 8 hours:
Debug logging enabled, log will be saved as C:\Users\xxxxxx/MakeMKV_log.txt
Downloading latest SDF to C:\Users\xxxxxx/.MakeMKV ...
Program hangs during Parsing file: /AACS/MKB_RO.inf
Internal SATA LG WH16NS40 v1.02
Log and Dump files sent.
Thanks Mike for all your efforts.
kfreeb
Post by kfreeb »
My computer is a Mac Pro 12 core 3.33 MHz Mid 2012
I have an Blu-ray internal drive that is now getting the following error:
DEBUG: Code 03DF/02/E3767A939283
I have another blu-ray drive that I've connected externally, using a Wiebtech Ultra Drive Dock v4, which does work still.
I had no problem with the internal drive till about 4 days ago, when is started to take longer to decrypt Blu-ray Discs. Today it just stopped decrypting blu-ray disk and presents the error code above. I've let it try and decrepit for about 30 minutes, but it never errors out.
My question is, is my issue the same issue everyone here is experiencing, or do you think my internal blu-ray drive has taken a dirt nap?
Both blu-ray drives are LG's, model WH10LS30, (working still) and Model WH14NS40, (Not working.)
Mac Studio M3 Ultra
96GB Memory
GPU 80 Core
CPU 24 Core
Sequoia 15.7.4
aerandir92
Post by aerandir92 »
I'll just add that I get
and then the process hangs there.
I can close makemkv, but the child process makemkvcon64.exe is completely stuck, Windows is even unable to kill it. I have to force reboot (Windows is just stuck at "Restarting" if I do a soft reboot).
cjblckwl82
Post by cjblckwl82 »
I am getting the same results.
I was told that a fix was pushed but I don't know if I have the fix or not, I am on version 1.14.2
Tried the BD disc again in question and it's been opening the disc for 13hrs with no end in site.
LG BluRay player (internal) connected via USB.
captin
Post by captin »
Another "lucky" one
Code 03DF/02/F079FED9918C
