Weird...both my LG's now hang which are internal drives but my external Asus reads just as quick as ever.
I'll have to try this debug report stuff to send to Mike.
BD or UHD no longer work
king_pin
Re: BD or UHD no longer work
Dump files sent.
teckman
I am still having the problem. It does not appear to be fixed. I re-downloaded the latest version of Make MKV and that didn't solve the problem either. Are you still working on the bug?
First post updated, please post the new debug code. This should be fixed by tomorrow, one way or another. Worst case - a few days.teckman wrote: Sun Jan 27, 2019 10:51 pm I am still having the problem. It does not appear to be fixed. I re-downloaded the latest version of Make MKV and that didn't solve the problem either. Are you still working on the bug?
king_pin
Another update.
My 2 internal LG's won't read DVD's anymore or they are just stuck.
My Asus external drive works no problem.
You have to close and restart MakeMKV. Also, you might need to power cycle LG drives, which means turning off and then on the computer. The code should be 03DF/02/XXXXXXking_pin wrote: Sun Jan 27, 2019 11:20 pm Another update.
Malachor
my error is
MakeMKV v1.14.2 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Cj/MakeMKV_log.txt
DEBUG: Code 0 at z3q2Zsw5q;dm{R\<:121273871
DEBUG: Code 03DF/02
before i was only getting
DEBUG: Code 03DF/02
im using asus bw-16d1ht 3.01 i was able to rip just a few hours ago.. but now i cant.
thank you mike for the hardwork on this
DEBUG: Code 03DF/02
DEBUG: Code 03DF/02
This is still the old one. Please restart MakeMKV, make sure it downloads updates.
grendelrt
I am still having the issue, my code is
DEBUG: Code 03DF/02/E064BA3E3F81
[rab]
I am having the same issue as before where it will take a very long time to try and open the disk and give Timeout Errors. This time it is around there is a new error DEBUG: Code 03DF/02. Last time i tried this, it took over 9hrs to get through all of those errors and finally create a dump file, so I don't have that yet.
One thing I have noticed is that it takes a long time to do the initial scan of the optical drives before you can do anything. around 10 minutes have elapsed on the most recent start of MakeMKV and it is still scanning. It just says
MakeMKV v1.14.2 win(x64-release) started-
Malachor
new error is
ChrisI
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.00
Serial number: SIK9KH2SF455
Firmware date: 2115-11-03 11:10
Bus encryption flags: 1F
Highest AACS version: 65
While parsing file /AACS/MKB_RO.inf
DEBUG: Code 03DF/02/F0ED16432FAA
System hangs. Cannot use file manager. Cannot kill process with task manager. Cannot shutdown. Must cycle power.
Do you need the dump file?
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.00
Mike,
Tried with a UHD that has worked previously. I'm using an LG BH16NS55 (fw 1.02) connected with a Unitek SATA 6G / USB 3.0 cable.
DEBUG: Code 03DF/02/067EFCA8EA7E
Backup failed
Also tried the same UHD with another LG BH16NS55 (fw 1.02). This is my main drive that I have used for most of my UHD/BD backups. It is in a Lite-on enclosure (model eHBU212). The old Liteon drive was on it's last legs so I switched it out for the LG drive.
DEBUG: Code 03DF/02/F079FED9918C
Backup failed
Dump has been sent.
Backup failed
Backup failed
Dump has been sent.
jon96789
I am having an issue... Inserting a disc in MakeMKV just hangs the app with error DEBUG: Code 03DF/02/6F4CB5E20C3C
Comrade_Ruckus
im getting this issue on the pink panther disc and that isnt even a blu ray. i got the same error you guys get 03DF/02/76A0C3CD522E
i dont know how to fix this and i would like to add this movie to my digital library and i have the full version of the software!
Has anyone gotten this software to work on the older versions?
