Problems with Kick-Ass
Has anyone ripped Kick-Ass on Blu-Ray successfully? Really appreciate any help.
Re: Problems with Kick-Ass
Hi!
Yes, I've successfully done BOTH a full disc backup and a "movie-only" backup of the U.S. version of "Kick-Ass" with no problems noted...
What problem(s) have you encountered?
Once the disc is inserted it takes forever to open the disc (10 min) and then once I check the video and audio track it begins to create the mkv, but then reports an error about 30 minutes in and terminates. I've tried a few times and still no luck. I was thinking maybe I need an updated svq file, but that didn't seem to work unless I had an old one. Thanks for the help.
Sounds like you have a disc that's either damaged or dirty - or a failing drive.
Post your log from the failed effort...
The drive is ok because I am currently ripping another blu-ray right now. The movie plays just fine on my blu-ray player as well. Unfortunatley, I can't even copy the log because the program prompts me that there is a fatal error and then just force quits. I had a similar problem with Avatar, but when I added the svq file it worked fine. I'm just ripping some of my other blu-rays in the mean time, hoping that I can find an answer. I'm surprised that I am the only one having issues with this movie. Thanks again for trying.
This proves nothing about your disc playing on your drive. Just take a minute to carefully clean the disc and try it again with your drive...The movie plays just fine on my blu-ray player as well.
(This Lionsgate release does not contain BD+ and, therefore, there is no svq requirement)
I'm in the process of ripping my entire collection, I had come to a full stop when I attempted to rip Kick-Ass. I have the Blu-ray and the DVD and neither would complete. the DVD will not pass the initial read and the Blu-ray gets all the way to the end and stops just before it completes with an error. I skipped it for now and continued with no problems after that so I'm convinced it's not the disc or drive and I have the most current makemkv as of this date.
After reading this I'll do a cleaning but it looks perfect so we'll see.
I cleaned the discs, the DVD doesn't get past the encryption before it fails, the Blue ray writes almost all the way through then stalls at the 2 minute mark and dies off. error says " The specified request is not a valid operation for the target device"
