How to Train Your Dragon 1 & 2 - Fail to decrypt
stuckinkodiagain
Post by stuckinkodiagain » Thu Jan 24, 2019 4:00 am
The newly-released UHD blu-rays of "How to Train Your Dragon" (2010) and “How to Train Your Dragon 2" (2014) fail to decrypt in the latest version of MakeMKV (1.14.2). The dump files for both films have been sent to svq@makemkv.com.
Thanks to the devs, as always!
turtounet
Re: How to Train Your Dragon 1 & 2 - Fail to decrypt
Post by turtounet » Thu Jan 24, 2019 3:30 pm
Same for me, didn't notice your message before so I also sent the dump files...
stuckinkodiagain
Post by stuckinkodiagain » Thu Jan 24, 2019 4:34 pm
turtounet wrote: Thu Jan 24, 2019 3:30 pm Hi,
Hey man, more is probably better. Cool!
xmenw
Post by xmenw » Thu Jan 24, 2019 9:13 pm
I just sent dumps too, but it seems like the Makemkv is not pulling the latest version of the hashed keys, I moved my file out of the folder to test and it didn't download a new version. I'm going to try with posted keys_hashed from the sticky, it does have 2 versions of HTTYD 1 & 2 and see if that works.
handcraftedbits
Post by handcraftedbits » Fri Jan 25, 2019 12:14 am
I think MakeMKV actually consults an online database of hashed keys. The text file is a fallback, and you have to update it manually.
xmenw
Post by xmenw » Fri Jan 25, 2019 12:21 am
handcraftedbits wrote:I think MakeMKV actually consults an online database of hashed keys. The text file is a fallback, and you have to update it manually.
I thought it downloaded the file, I think I remember seeing a status message that it downloaded the latest file. Maybe I’m wrong, hopefully someone can chime in.
st4evr
Post by st4evr » Fri Jan 25, 2019 2:57 am
The hash key file that is manually downloaded here in the forum is NOT the same file/key list that is updated by the Mike’s online database. One is publicly available and the other is stored within program files and maintained separately.
xmenw
Post by xmenw » Fri Jan 25, 2019 3:02 am
st4evr wrote: Fri Jan 25, 2019 2:57 am The hash key file that is manually downloaded here in the forum is NOT the same file that is updated by the Mike’s online database. One is publicly available and the other is stored within program files and maintained separately.
Thank you! Is there a location of the file that’s visible or is part of something we can’t see.
st4evr
Post by st4evr » Fri Jan 25, 2019 4:58 am
It’s part of application files not readily accessible.
xmenw
Post by xmenw » Fri Jan 25, 2019 3:37 pm
st4evr wrote: Fri Jan 25, 2019 4:58 am It’s part of application files not readily accessible.
Gotcha. Thanks.
xmenw
Post by xmenw » Sat Jan 26, 2019 4:10 pm
Seems to be working now! Thanks all.
turtounet
Post by turtounet » Sat Jan 26, 2019 7:47 pm
Working for me too :)
FlyGuy
Post by FlyGuy » Sat Mar 02, 2019 9:13 pm
Just picked this up but not working for me. Tried downloading the latest hashed keys file manually too but getting volume key not found error.
MakeMKV v1.14.2 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\**/MakeMKV_log.txt
LibreDrive firmware support is not yet available for this drive (id=F8B3C9080B22)
Saved AACS dump file as C:/Users/**/MakeMKV/MKB20_v65_How_to_Train_Your_Dragon_7FB8.tgz
DEBUG: Code 0 at FcF^D,r,a.ZGY1pC:29396115
DEBUG: Code 0 at FcF^D,r,a.ZGY1pC:213134262
Debug log started at Sat Mar 02 21:09:28 2019 , written by MakeMKV v1.14.2 win(x64-release)
001005:0000 MakeMKV v1.14.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\***/MakeMKV_log.txt
001011:0000 LibreDrive firmware support is not yet available for this drive (id=F8B3C9080B22)
DEBUG: Code 2317353381 at 3tu+2QPU[=7Te!Z9e:121263268
DEBUG: Code 0 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 1 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 2 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 3 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 4 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 5 at 3tu+2QPU[=7Te!Z9e:121263291
DEBUG: Code 2317353381 at 3tu+2QPU[=7Te!Z9e:121263153
DEBUG: Code 0 at z3q2Zsw5q;dm{R\<:213140426
DEBUG: Code 0 at FcF^D,r,a.ZGY1pC:29401014
DEBUG: Code 2147483648 at z3q2Zsw5q;dm{R\<:121265223
DAFD=PAAAADAAAAEABDQkEHgACAQ==
DCE=dgRsNb9GIwm3C4exlM3NJEBVLsnhQ2XhERxVuBBrYT44LocFJnvmk+rnlXtbAvve4jTvraHnvlXDNL/mNjhQKs4EyDZ8218Ea9LrajgoPjKd66qt9ibYKs/5HkLI7kCFKOktYVcyge0RzerKtpOAfvUBf/KeZaE5Sw==
DCE=EPab0ihfu1sas4EUy8SAo+bNKTeZb8Br6+F+yfVmRBxXRBL+fpbgD+LOL39U8L6TBQvcueMdtg8GTkJPb0ktC2NYO+68V/pm3PoKAHMirtI+1rOoj29IuZcWy6PO5ok4lE9e4n4rVu9Lim5HxK9ZYMYkxyv11O1ILQ==
003332:0000 Saved AACS dump file as C:/Users/***/MakeMKV/MKB20_v65_How_to_Train_Your_Dragon_7FB8.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at FcF^D,r,a.ZGY1pC:29396115
001003:0020 DEBUG: Code 0 at FcF^D,r,a.ZGY1pC:213134262
Application exited at Sat Mar 02 21:11:55 2019
mitchell1848
Post by mitchell1848 » Thu Mar 14, 2019 6:23 pm
I was not able to back up How To Train Your Dragon 1 with 1.14.2, though I had success with HTYD 2. Today I had success with the updated version of MakeMKV 1.14.3.
Thanks for the upgrade.
FlyGuy
Post by FlyGuy » Fri Mar 15, 2019 2:08 am
Version 1.14.2 worked for me too. Thanks!!
